Surrealplaces
Administrator
Staff member
Might as well start a thread for this one. Project will be updated as info comes in.
The triangular balconies give me visual pleasure but they aren’t going to be particularly useful. Developers will probably put the air conditioners on them making them useless and ugly.
Is this the first proposal where the recently demolished housing was
The townhomes are called Vanguard and the condo buildings are called Cadence. Sales center opens this weekend and it looks like the DP for the townhomes is already approved, so construction on the townhome portion of the block should start sometime in 2026.
Have the old Varsity Courts Townhomes been demolished then?
Not all of them, I believe the rest are scheduled to be demolished in 2026.
This is what things look like right now, with some roads and sidewalks built out (Block 11 highlighted in blue). All of the townhomes within a block of 32 Ave are still there.
I've never lived in apartments of this size, but are they not typically central air? Considering these units are 500-700 sqft, I can't imagine they all have their own furnace and A/C.
Another article on this project (both townhomes and apartments):
Yes. Typically some central heat/cooling system pipes hot and/or cold water to a fan-coil in the unit; effectively an in-wall radiator with a fan pointing at ducts.
This is a solid addition for the area. We really need more of this 'missing middle' scale in Calgary. Curious to see how the retail/main floor interface works with the sidewalk once it's finished.
