April 2
April 27
May 4
The barges that were used for 150.
It appears that they are pulling out some of the braces - to put caissons in those spots ?
Demonstrating why he wears a face shield.
May 9
nobody messes with the bridges - easier to cut out part of your wall.
Slant capable - apparently putting in whatever the cables tie off to.
Preparing runs
May 14
Stubby rig for low clearance - put in the H-Piles under the edge of Wacker
Working on the wall
May 16
Tightening and filling
Tied off (hose clipped off)
The land side - the angled brace is tied off to something the slant drill put in, the sheet piles have been welded to the brace.
May 29
A view soon gone
May 30
Now it's started. The chains are holding up a rebar cage that is suspended in concrete.
June 06
A deft hand adjusting the yard stick
Some serious re-bar - these appear to say V 1 S = 75 If I am reading this right it is from V, a #1 sized rod (the biggest ?), Steel, and is grade 75.
Slurry pipes. For when a thick muddy slurry is used in the shaft to keep the walls apart, and you don't want your concrete diluted as it sinks to the bottom. The pipe is assembled, run to the bottom of the shaft, and the concrete (heavier than muddy water) displaces the water up the shaft.
Working on the river
June 10
Unloading the auger
A can for bringing up thin mud - stuff that would slip off the auger ?
Attaching a load tester [ O-Cell ]
Several of these have been assembled - looks like the hole would allow the tremie pipe through - not sure where or why they would sit in the pier.
July 5
July 13
July 18
Making 2 long bars into one really long bar.
Duct tape for the win.
Guiding in the Tremie pipe
July 26
This view of the Sears tower will be lost
July 31
Taking the long coupled rebar off the barge - one at a time - and lowering them into the shaft with the already hefty cage in it.
Aug 6
Another case of hitting slime - something odd is under our clay ;-)
Still not sure where these are used, but they seem to be building slightly different ones for each big pier.
A working river
Aug 10
Deep foundation work is completed - starting on the mat (no basement here)
Spud Barge
Putting in the spuds
At first I thought it said TONKA - wish it did
[TONKA made metal construction toys back in the 60's/70's, all this shade of yellow]
Marking where the foundation piers lay waiting.
