dowlingm
Conde Nast and Morgan Stanley are behind separate proposals to the Metropolitan Transit Authority to build up to 70 storey developments over rail lands on New York's West Side (11th Avenue between 30th and 33rd Streets).
It's a bit like the proposal (which I believe has been moved away from) to build the Whitecaps Stadium in Vancouver over several rail lines.
If rail is going to cut through the city then we should do something with the airspace I think. Further out on the Lakeshore West line east of the Gardiner I'd love to see at least decking used to create new parks or rec facilities like tennis courts. Because of the use of diesel trains you couldn't do it the whole way but short stretches would also help reduce the surrounding noise level.
The trick would be to preserve enough space underneath to allow doubleheight containers and electric GO trains...
