archited
The ebb and flow of possibilities will continue; if I were Alldritt I would wait another year to see where the economy settles vis-a-vis Edmonton.
No I think Alldritt will sit on it for another year then sell it off. They have loads of other properties they can sit for longer.
Yes, a decent sized hotel/residential tower here would be great and I hope it does happen soon. However I wonder if the stigma of this area is too great for that.Leston, Westrich, ONE, Rohit and other developers should be paying attention.
Also, the likelihood of an 80 story tower is next to nil, however a midrise or highrise with a hotel and residential suites should still be doable.
Correct me if I'm wrong, but this isn't the parcel that was proposed for the 80 story correct? I think that was across 96st and towards the convention centre. Or was this to be part of it as well? If it is separate, hopefully someone will at least pick up this small parcel and do something with it.I'm giving it another 3 years or so. I believe that's when the sunset clause kicks in. I'm hoping a more competent developer takes over.
Thanks! I knew the design was definitely different, but figured same footprint. Interesting that a smaller mockup would've been part of it.^ The project was actually meant to cover both parcels that you refer to -- with a project mockup to be built on the lot between the Russian Orthodox Church and Jasper Avenue. The design that you are sharing was an earlier version designed by Kennedy; there was a later substantially different design prepared by Gene Dub.
As opposed to what the City did with Hall D?This is one of the select areas downtown where there is a good view of river valley from Jasper Avenue, It would be a good idea for whatever is built to preserve as much of this as possible, as well as access to river valley.?
