Anything outside the stations has no impact on the line opening date. Road work is one of the last thing to be done that only effect surface traffic. If there is sidewalks work around the station once its in service, entrance will be open with limited access until the work is done.
What we can't see is the work inside of the stations themselves with Kennedy being the last one as well Yonge to be fully completed. The rest should be completed by now or needing small amount of finishings touchup.
As noted, Yonge could be a problematic station as somethings have not worked out as plan or have gone south. Until Yonge is completed, the line will not open even for bypassing it.
Drum do you have any insight what the problems at yonge station are exactly?
Yes, upon re- reading, my post might have been a bit misleading. I suggested that resurfacing Eglinton might be part of the project completion but wrongly implied that it would hold up opening of the line.
People move into houses where the grass & landscaping has not been done and the driveway is unpaved.
Its a feeling and reading between the lines of things been posted by Metrolinx and others.
Its the same thing for moving into an condo where there work both inside and out still taking place
I don't believe the roads not directly outside the stations are part of CTS scope of work.
Yes there are if it was dug up for underground work or impacted by construction of the stations. Outside the construction zone, the roads are the responsibility of Toronto.
Im wondering if it has anything to do with the planned shift of the Eglinton platform several meters to align with the station below? I don't frequent the subway, so Im not sure if that work has even started yet? I thought that there were going to be a large number of Eglinton station closings to accommodate this work, but Im not aware of any closings other than for the signalling upgrades....
I was wondering the same thing, the Eg station thread has a bit of an update. Platform shift has apparently been minimized to leave the pocket track.
There's still some finishes to apply but from my understanding most of the work on the extended platform has been completed.
a lot of the signal upgrade closings also allowed for the platform shift. It seemed like they were closing Line 1 through this stretch almost every other weekend to get the work done for a while there.
thanks. I didn't even know about that whole thread...
There's this new invention called photography. Show us what is finished, what is about to be finished, and what is way behind.
Photography won't show us engineering flaws. I highly doubt it's a structural problem anymore. They can finish Eglinton in half a year.
Since we haven't seen successful high speed footages, it might not be safe to run trains in tunnels at high speed. Hence they can't open the line. Who knows what they need, redo the tracks? buy new trains? build new tunnels? build a new line? ML are fools
