^ CN holds all the cards. If they don't want to participate in a "little" smart scheduling it's their call, as has been debated here for years. What may seem "little" is actually a logistical challenge when you think of the length, speed, and acceleration differences between a GO train and a CN freight train.
It's really a moot point now. It appears GO has the funding and is working on the designs to implement a 3rd track. The Province clearly feels it's worth it and the City has (and other municipalities to the west) have been demanding more service.
This is the challenge with the notion of a "little smart scheduling".
The planned third track through downtown Brampton will be at-grade. Not elevated or tunneled.
Indeed. Planning is well underway. The embankment along the south side of the corridor through Downtown Brampton will become a solid wall, and a new transit hub (currently in the design phase) will replace the downtown transit terminal, providing the space required to get that third track through.
I do wonder where they're going to squeeze it in, then. I guess the north portion of Brampton GO can be moved to accommodate a third track on that side?
Edit: Sorry, didn't read ShonTron's comment...
If it's going on the south side, won't they need to rebuild the south portion of the VIA/GO station, which they just built a few years ago?
How time flies... the double tracking and added GO platform dates to 2009. That's practically brand new by transit infrastructure standards, but what has been built mostly won't need to be torn out. It will simply be "augmented".
in the scope of what is getting moved around to redevelop Brampton's downtown, the demolition of the transit center and whatever gets done to Railroad St is not unreasonable.
It may not be pretty, but it will work. The sooner the better.
As a Mississauga resident I’m jealous that the lrt and go train could both service the downtown. I’m sure no one near square one gets excited on the other hand about taking a lrt to cooksville.
Also, the fact that Milton line (which has wider coverage in Mississauga than Lakeshore line) won't get RER services any time soon makes it even worse.
^ Yeah but Brampton is jealous Mississauga has TWO GO lines, one which can easily accommodate 7-day, all-day, two-way service because GO owns it and it's going to be entirely electrified. :)
3 actually. Kitchener line stops at Malton. If we are negotiating, then let's call it 2.5 lines!
It won't be as early as the Lakeshore line (which is close already) - but with the feds already having committed funding for the Milton line, it may not be that far behind the other RER lines.
So the pushbox at Port Credit is on the west side of Hurontario, but the pushbox at the QEW is on the east side?
A number of piers are now pour with a few others been worked on for the elevated section. The south side of the 403 has been built up to be the same level of the existing bridge to the east to allow tracks on it.
All the excavated guideway are in various stages of work with some seeing embedded rebar pier supports.
The westside sidewalk is close and being dug up along with the embankment by Mary Fix Creek, Traffic using the new west road to allow work on the creek that is seeing the removal of all trees and bushes. The walkway bridge over the creek is close as it will be remove along with the remaining embankment to allow the building of the new road bridge.
The Port Credit pushbox has a number of issues for being push under the rail corridor with no date as to when it will happen.
  • Wow
Reactions: max
The area between Matheson and Watline has concrete flower box area on either side of the centre poles foundation pour with dirt in them. The next block to the north is being ready for concrete to be pour. This will stop people trying to cross the tracks mid block.
Noticed a stockpile of precast ties in the storage area at Cooksville area. Must going to be use for the tracks from the maintenance yard to Hurontario.
How will the tie-in for the 403 bridge work? Will the line cross the southbound lanes of Hurontario at-grade or will it rise straight from the guideway?
