queen station today
These are very fast in TO standard…
Agreed! Shouldn't be long before they start demolition of the north/west portions of Eastern and Queen bridges.
They are about a year behind schedule on these bridges. I’m assuming it’s several years of prep work (that is behind schedule as the third track was supposed to be laid and operational by autumn 2024) but once that’s done the bridges go up in a blink.
Does the larger bridge over Gerard need to be replaced or can that area of the corridor fit the OL portal and 4x GO tracks?
I believe they are building the Gerrard/Carlaw Station (elevated bridge structure station platform) part of the OL contract instead of these rail corridor expansion.
I believe they don't technically need to fit the OL tracks and the portal into the existing corridor at Gerrard, as they've expropriated part of the former No Frills site for the portal (which is why the No Frills had to close). The station itself will be on a new bridge next to the existing GO bridge.
So unless they're also raising the GO corridor at that location, they probably can keep the existing bridge. And while we should never put a ton of stock in renders, the renders of Gerrard Station seem to show the current GO bridge, for whatever that's worth.
Edit: found the diagram of the layout at Gerrard-Carlaw
Source: Metrolinx
Source: Metrolinx
This diagram has more detail and makes it look like it's all one bridge but that might be just for simplicity's sake.
I don't actually see Ontario line tracks on this diagram? I seems it's just the four GO tracks? Am I wrong?
Also I thought there wasn't going to be a GO station here?
How old is this diagram?
You're totally right. Just disregard me! 🤣
Source: Metrolinx
The existing bridge structure over Gerrard and Carlaw is wide enough to fit 4 tracks as were the structures over Dundas and Logan, but the corridor needed to be moved southeast before the Gerrard/Carlaw bridge structure to fit the Ontario Line in the same corridor.
