W. K. Lis
Superstar
City:
Toronto
More escalators mean more cost to purchase, install and maintain them in the long run. Better to have 3 longer escalators all the way down than 2 to an intermediate level and 2 more to platform level.
Sigh OBC. When up to 20m escalators is common, and up to 40m is possible.
I imagine this is what someone bringing ideas to TTC/Metrolinx to save costs hears from them - excuses on why it can't be done, when it can! There's a reason that North American transit costs are so high...
Also means that should one escalator be down for maintenance, there still is others available to at the very least part of the run.
That was the problem with the Spadina moving walkway, there was only one in each direction. Should have been split to go at least half way. That's how they do it at airports.
toronto647
Active Member
Ontario Line Science Centre Update
I apologize if this was already mentioned but was new information I found after speaking with CreateTO and various senior city officials.
Metrolinx is acquiring a portion of the western part of the @HousingNowTO at 805 Don Mills where the Ontario Line will travel over. For the lost space, Housing Now / CreateTO will purchase a small plot of land from the Church at Eglinton & Ferrand. This will allow Ferrand Drive to open up on Eglinton and to Gervais through a 4 way signal light. Furthermore, Ferrand Drive will be extended south pass Rochefort to St. Dennis Drive. This will create easier transit flow to the bus terminal and less gridlock in the area.
I suspect this information will be more detailed in the North Civil's RFQ which will be released in the Fall.
See pictures below:
W. K. Lis
Superstar
City:
Toronto
The Barrie Line isn't stopping at King-Liberty, so it's a choice between a station that serves one line and a station that serves a different line. Exhibition still makes more sense.
Can change in the later years. They can add, subtract, switch, or move the flow around.
ARG1
Not that easily. They're still only build the platforms on the Kitchener Line tracks, which means for the barrie line to access those platforms, they need to step over the Kitchener Line's trackspace, which goes against how Metrolinx is planning for GO.
44 North
There is one kinda obvious advantage....escalators need maintenance and sometimes break.....having them split allows that to be done in stages and allows for better passenger experience while the work is being done.
Can still break it up, by having six really long escalators side-by-side.
Now at its root does this stem from King's Cross fire / Trench Effect? Surely any issues with a long escalator can be solved with modern fire suppression and ventilation. Needs to be an exemption.
HousingNowTO
Active Member
City:
Toronto
See pictures below:
View attachment 378276View attachment 378277View attachment 378278
Did those images come from Toronto AIC - or somewhere else..? Thx!
toronto647
Active Member
Yes came from Toronto AIC through the revised documents submitted to the city last week. The other comments about the Church land property came through a community consultation. The comments about the Ferrand Drive south extension came from the Rochefort redevelopment submission through AIC. The comments about the Ontario Line on the Housing Now Lands came from Metrolinx and backed up by your folks submission.
HousingNowTO
Active Member
City:
Toronto
Thanks - need to look at the new stuff in AIC.
ARG1
ViveleCanada
Active Member
Hopefully this doesn't happen to the OL
*Knock on wood* I think the Ontario Line should be fine since it's using catenary technology rather than the Innovia technology that's used in Scarborough. Ottawa's frankenstein half-LRT half-metro made it through January's snowstorm without incident.
robmausser
The OL wont be built with gadgetbahn fantasy "wanna-be Maglev" technology like the SRT.
Who knew that pulling a motor apart and laying it out along the entire track would be susceptible to even the smallest amount of snow?
generalcanada
Active Member
also remember that the streetcars worked "semi-fine" the only problem being traffic.
TTC line 1 had issues but only because they needed to run slowplowing trains around davisville and yorkdale parts of the lines.
officedweller
City:
Vancouver
That's right - the clearance between the linear induction motor and the reaction rail is 11mm.
That's where the snow or ice build-up is a problem.
