I'm not sure I understand the skepticism. It's not unprecedented to operate at 40 tph, and the line is being designed for it from the ground up, not as a retrofit.
Edit to add: we shouldn't discount how useful the increased reliability of OL will be. Huge reduction in service disruptions due to PSDs keeping people and trash off the tracks. I don't often ride the subway but it seems like a disproportionate amount of the time there are service disruptions. I went to a game at Scotiabank a few weeks ago and had to walk from Dundas because of not 1 but 2 incidents on Line 1.
It's not unprecedented although it's certainly not common either, and as you point out, this line is being built from the ground up.
My concern however stems from the details - as that is where the devil lies. From what I've seen of the track layout, it should allow a 90 second headway in regular revenue service, but the layout of the yard access - and the lack of on-line storage tracks - will make it awkward-to-difficult to inject the required trains into service to achieve that headway.
The assumption is that the TRs won't reach 90s is because the line's infrastructure, not the train alone, is not designed to handle that frequency. My understanding is that the time a train takes to clear the platform plays a big role. This gives shorter trains an advanatge.
For the current subway: The possibility to retrofit that is unclear. Steve Munro stated in
2006 that achieving 120-second headways on the current subway lines is difficult, and 90s is impossible because the terminals are not designed to handle them. I don't know if that has/will change with the current extensions.
Sure, it's the infrastructure. The vehicles themselves don't have a bearing.
There are lots of opportunities to allow for improvements to the headways. Some of them are already underway. It should be noted that the passenger flows are one of the biggest obstacles, and those are currently being fixed at many stations. But one of the biggest constraints to improving it to below about 120 seconds is the track layout, and more specifically the double crossover south of Finch Station. (At the other end, the use of a single terminal will also be a constraint, although this can be overcome much more easily on the west side than the east by alternating trains between two terminals.) There are ways of fixing this, but they will require money.
i am wondering, maybe others are too, but yes the go corridor is 4 tracks, 2 are specifically for stouville and 2 are for LSE.
Essentiallsy 2 separate 2 track corridors with long 300m trains. Express trains are included in this as well
whats the theoretical capacity of that?
That's not the best way to allocate the capacity on that line - it would be far more efficient to allocate one set of tracks to local/stopping trains, and one set of tracks to express trains. This way, the trains on each set of tracks will have a similar set of stopping patterns and speeds and performance.
As for what the capacity of the line is - that's going to be heavily dependent on the signalling used. If a similar set up to the Weston Sub is used - signals every half-mile with a 6-step signal progression - you could have trains running at 90mph every 3 miles on each track. What is installed on the Kingston Sub right now is somewhat less capable due to the distances between signals.
