dahusbandofbath
Active Member
City:
Toronto
Lets compare, shall we?
Current Construction site, aerial pic from 2020:
When comparing this to the photos above of the building rising, we can see the footprint comes pretty close to the corner of Front and Jarvis where the sidewalk is actually on the narrow side, and then is further set back, angling northwards as it approaches Market Lane Park.
Now, how did the old market look in this regard?
From 2009:
In the older pic, the building to curb sidewalk ranges from 2.2M (barely the City minimum to ~9M on an angle before the corner cut-out
The new building.....you can't see correctly on the aerials............so let's look at the landscape plan:
For those reading along, all measurements are in MM unless otherwise indicated.
I read no extra space at the corner of Front and Jarvis, it looks like a bare minimum of 2.1M (not ideal, but I digress)
I don't see a material widening on Jarvis either.
If I'm reading this correctly there are 2.1 m from the curb to the roofline, which overhangs significantly.
Northern Light
Superstar
2.1M is the City minimum standard wherever feasible for a pedestrian clearway/sidewalk.
innsertnamehere
Superstar
City:
Toronto
It’s a massively improved public realm, but yes, a lot of it is covered. Still a lot more space on the corner overall for pedestrian circulation.
Townie
New Member
The arch installation continues and they have now completed 5 'bays; on both east and west sides with all their arches. They seem to have no more columns or large pieces on hand so I assume will get more in the New Year. Only 3 more bays - on east and west - to go. Sooner than later we should start seeing some walls appearing and should then get a better idea of how the final building will conform to the rendering. So good so far but ....
As much as I'd love to see this project finished, I can wait a while -- and while waiting, continue to admire the steel framing, which looks amazing. It's so elegant and spare.
Northern Light
Superstar
Photos taken as nightfall arrived on December 28th, 2021:
First, one w/St. Lawrence Hall lit up in the foreground:
Now the rest from the East and then the South:
Look up:
Now, across the front, behind the hoarding, looking east:
That last one gives a good perspective on public space in front of the building, and how it narrows from west to east.
I had a good look at both sides.
I believe the corner of Front and Jarvis will be a be a bit tight for crowds (as it was before), but there is ample space further west.
AlvinofDiaspar
Moderator
City:
Toronto
Look up:
The original competition proposal was a lot more generous at the corner by the virtue of it not being closed off (even though it had a support column) - from the UdeM CCC Archive:
DogLover
New Member
After this is done, will they be developing the St. Lawrence Market South building on The Esplanade and Lower Jarvis? Would love to see a permanent structure similar to this built in its place.
