interchange42
Administrator
Staff member
So they're doing exactly what Uptown said would be on their tower..
Shows that it wasn't that hard to do at all, they just decided to go the cheaper route..
But this is looking good!
Clearly Etobicoke has higher aesthetic standards than downtown Toronto. Wait, that can't be right.
Oh yeah, Pemberton is just a shitty developer.
this has got to rank right up there amongst the dullest looking buildings of the past 5 years. The roof detail is about its only positive recommendation, though I cant help picturing a bow on top - the world's largest birthday present. Also if you look at the model, those vertical lines from the roof elements continue down the balconies on each side, whereas the actual photos dont show any sign of that.
Can we officially declare that the cheaping has reached epidemic statues in Toronto? Much like AIDS, there seems to be no cure.
The vertical lines are probably going to be done by deck to deck privacy screens?
You all know that the building is not finished yet, right? There seems to be some competitive conclusion-jumping going on above!
