General rating of the project
  • Great
    Votes: 8 27.6%
  • Good
    Votes: 16 55.2%
  • So So
    Votes: 3 10.3%
  • Not Very Good
    Votes: 2 6.9%
  • Terrible
    Votes: 0 0.0%
I thought Batistella used curtain wall, not it's cheaper little brother, kinda disappointed to find this out.
From what I understand, curtain wall is rarely used in residential applications given the complexity that is added with balcony openings - you end up with a hybrid system w/ many points of potential envelope failure. It may be warranted for much larger towers as the installation can be more rapid. (Please correct me on any of this if I'm incorrect as I'm genuinely interested)
But - Why does it matter what system was used, if you couldn't tell the difference visually?
Window wall is a cheaper system that sits on the slab edge, but provides far less insulation at the slab edge (usually about 1" max) and requires a membrane tie-in at every single floor. The installer has to be on their game at every tie-in or it will leak eventually. Curtain wall is supported off the edge of the slab, uses stronger, thicker extrusions and has thicker insulation at the slab edge (the depth of the back body of the mullion is usually mineral wool insulation) plus there is about a 1" gap between the mullion and slab edge that gets filled with more mineral wool insulation). In addition, the curtain wall system is completely face sealed, so there are no membranes to tie in at every floor. Curtain wall is a far superior system than window wall, they look the same, but looks can be deceiving. The problem is curtain wall goes for about $150/square foot whereas window wall is closer to $80, so it's all about cost. Curtain wall will outlive a window wall by a lot, but most developers don't care what happens to their projects in the future, they get their money and get out leaving repair costs to the owners.
