Mull
Active Member
That glass front on the ground level floor is too pretty for that spot. Happy its being built!
Pretty much never. Wood shrinks over time and steel doesn't, so to use steel you have to account for it.
It’s not “I was in the pool!” level of shrinkage.Pretty much never. Wood shrinks over time and steel doesn't, so to use steel you have to account for it.
It averages 1/8" per plate, and there are 3 plates per floor (2 top and 1 bottom plate on a framed wall). 5 floors of wood framing equates to just under 2". It's not huge but can lead to sloped or warped floors. It's not a structural concern but would be noticeable.It’s not “I was in the pool!” level of shrinkage.
How long is that long? 10 years, 50?The floors shouldn't settle where they are anchored to the concrete or steel. The stud walls will separate a bit from the floors around these structures.
That doesn't include settling. The heavy concrete elevator core could settle more than the wood frames shrinkage. I doubt this building will survive that long.
