UrbanWarrior
Hoarding + heavy equipment = imminent construction.
Yeah that excavator has been there since they tore down the brick apartments
The hoarding is a good sign though. The next sign to look for is the caisson drillers showing up.
This building will be constructed on foundation footings instead of drilled piles.
You have no idea how glad that makes me. Soon the noise from Ricardo's will be blocked!This building will be constructed on foundation footings instead of drilled piles.
It does still require excavation. The basic difference is a footing is a wider area flat of reinforced concrete that the foundation is then placed upon. It’s spreads the load of the building. It’s is placed much shallower than piles, which are much narrow, but go much deeper into the ground. Piles are a lot of work if you have to go through rock.I’m a construction dummy with a question, What is the difference with foundation footings? Does it still require excavation?
Already? Jesus.
