M II A II R II K
Car Capacity Is Not Sacred
September 1, 2010
By Dan Bertolet
Read More: http://www.publicola.net/2010/09/01...ed&utm_medium=feed&utm_campaign=Feed:+publico
Supporters of “road diets†are quick to point out that even when car travel lanes are eliminated to make room for bikes, not to worry, there will still be sufficient capacity for cars. And even though that has been blindingly indisputable in several recent Seattle cases, the naysayers howled away nonetheless—a sad commentary on how deeply in denial our culture still is when it comes to the problem of car dependence. But to me, the dynamic of that debate also reveals a troubling acquiescence—by both sides—to an ostensibly inviolable ground rule: Car capacity is sacred.
- It may well be that in today’s political climate, the only way cycling and pedestrian advocates will get the infrastructure they want is if they assure the masses that car travel will not be impacted in any way. But the trouble is, that position suppresses the reality that cars are in fundamental conflict with walking, biking, and transit.
- In urban areas that are dense enough to support efficient public transit systems, officials often negate their own efforts to increase usage, by simultaneously spending huge sums to make it easier for people to get around in cars. When a city’s streets or highways become crowded, for example, the standard response is to create additional capacity by building new roads or widening existing ones. Projects like these almost always end up making the original problem worse—while also usually taking years to complete and costing many millions of dollars—because they generate what transportation planners call “induced trafficâ€.
- The eventual result that the new roads become at least as clogged as the old roads, though at higher traffic volumes, and the efficiency of transit declines. These negative outcomes are compounded by the fact that, in the short term, temporarily improved traffic flow reduces commute times for drivers on the expanded roadways, making it easier for people to justify building houses, malls, and office buildings in formerly inaccessible outlying areas—and , in turn, eventually makes all the original problems worse.
- The only way to break the vicious cycle is to invest our limited transportation dollars in infrastructure that will help make walking, biking, and transit more attractive than driving. And here’s where we need to start being honest with ourselves: If we are serious about creating a city in which significant numbers of trips are made by modes other than cars, then we will have to accept that driving will become less convenient than it is today.
September 1, 2010
By Dan Bertolet
