micheal_can
Pearson should be for out of province and out of country large aircraft flights, whereas Pickering should become one for smaller, or more local domestic flights.
The problem is how do you make connections. The two sites are about 50km apart on opposite sides of a heavily urbanized area. A dedicated shuttle? In anybody's plans let alone anybody's budget?
There are a number of ways to split traffic between two airports in a region.
London Heathrow focuses on International long haul flights, Gatwick takes a mix of airport traffic (International, Domestic, Full Service, Low Cost), Stansted does mainly low cost airlines to Europe, Middle East, and Africa, Luton does mainly low cost airlines to Europe, Southend has emerged as another low cost airline airport, and City sees regional traffic mostly.
In NY JFK and Newark both focus on Domestic and International flights (with different airlines using either airport as their hub), while Laguardia sees mostly regional traffic.
There are many other examples where one airport focuses on International flights with the secondary focusing on regional flights and/or point to point style airlines. Air Canada would never allow their flight network to be split between two airports (especially given their current agreement with GTAA). So Pickering would have to attract a new regional/point to point/low cost airline, Westjet has grown out of their LCC roots and is truely more of a competitor to AC now. So unless Porter decides to move to Pickering there would have to be a new canadian airline for Pickering
If you have $20k try Piano X, but you can get good numbers just by using wiki, although be careful as the anti globalization crowd seems to keep editing this stuff, so cross check with individual manufacturers numbers to be sure.
You bet, except they have a choke point beyond which the airport becomes dysfunctional. JFK hit that 20 years ago ( on time performance crashed, similar to what happened at Pearson this February ). The FAA implemented an enforcement action/restriction, 40 movements a hour per runway that is still in place today.
Well, you could use a high speed train that basically follows Highway 407. There is enough space for it.
Pearson could be for all Star Alliance airlines (both domestic and international) and non-alliance international airlines, while Pickering can be for all airlines belonging to an airline alliance that isn't Star Alliance (both domestic and international) and non-alliance domestic airlines.
After all, many airports segregate their terminals either by flight routing or by airline alliance.
Which airline alliance would be a fit for WestJet: SkyTeam or OneWorld (or a smaller alliance or no alliance)?
Does somebody hopping in from say, Albany NY or Bango ME, have to land at one airport then schlepp across town to another?
A dedicated rail/bus shuttle could probably do it provided it is part of the funded airport plan and not a 30-year later afterthough. Make it too inconvenient, expensive, convoluted, etc. and travellers from the feeder areas will say 'screw it' and drive.
What if you made Pickering the Cargo/small plane airport? So, companies like Fedex, DHL, UPS, etc could only fly into Pickering and not Pearson. Also, any 100 passenger or smaller plane lands in Pickering as well. Leave Pearson for all the heavy haulers. At the same time, a (high speed) rail line through the Mid City corridor be built.
Read several of the above posts. I doubt limiting freighters and biz jets would make much of a difference and, as far as I know, general aviation are already locked out of Pearson (could be wrong). A high speed dedicated rail linkage - paid for by whom? Left over money from all of the other transit needs? Toronto? Durham? Province? Feds?
