At one point, earlier, the timeline showed the first year of preliminary work (Toronto Water and/or Hydro) as 2023.........so timelines have slipped.
I read the recent update you noted above........... I think looked to other sources.......
It's worse than that...........keeping in mind all dates can be moved both forward and backwards.
Internally major construction is currently programmed for 2028-2029, both north and south of Dundas.
Toronto Hydro currently has work programmed south of Dundas, on Yonge for this year. (2025)
Substantially correct.
There were a couple of blocks with varied design options, but the intent was to retain the ability to run the Yonge Night Bus regardless.
If the John Street revitalization is anything to go by this should be kicking off around 2050!
Regarding the elevator situation here, we've been contacted by the team designing a building...
…for the first time since we began reporting on elevator ratios about two and a half years ago.
Our reporting on elevator ratios was kicked into gear when the 123 Edward proposal by Crown Realty Partners included 3 elevators for 1,110 units, an outrageous ratio of 1 elevator for every 370 units. (A subsequent resubmission for 123 Edward added far more elevator service, now one for every 115 units.)
We had heard that 90 suites per elevator had been an industry rule-of-thumb over the years, Understanding that one building varies from the next in a variety of ways though, we wanted to better understand elevator service planning, so we spoke in the summer of 2022 with Rob Isabelle, a professional engineer and COO at KJA Vertical Transportation Consultants. With widely respected expertise in the field, Isabelle's practice extends across Canada and into the US. We learned from Mr. Isabelle that there are indeed many factors taken into account when recommending elevator service for buildings... but few actual governmental requirements: developers legally only have to provide a single elevator to meet fire code.
The number of factors in play — among them number of storeys, height of the storeys (distance from floor slab to floor slab), number of units, number of total bedrooms, size of the elevator cab*, and maybe the most important: the speed of the motors, measured in feet per minute — determine how long it will take on average for an elevator to respond to a call. The type of building plays a major factor as well; residential towers face more spread out peak travel periods and patterns than do office towers or hotels or hospitals, for example. For our purposes, we are looking at residential elevator service.
*(The size of an elevator cab allows more or fewer people to ride, but it's generally commercial buildings, which have much higher peak-time demand per square foot, where elevator cabs are nearly universally larger to any significant degree.)
The typical Toronto residential tower at the time that the Tall Buildings Guidelines were put in place was around 40 storeys tall, and the 750 m² floor-plate the City was looking for normally provided 10 suites per floor (so about 400 suites per building). Toronto residential buildings have typically provided 10% of their suites in three bedroom configurations, 20% in two bedroom configurations, and the rest in one bedroom or studio configurations. Those floor-plates were typically specced with four elevators, or one elevator for about every 100 suites. We had not heard horror stories of long waits for elevators in those buildings, unless of course elevators were out of service for repair, or placed in move-in/move-out service. There are such buildings, though, with fewer elevators than the typical example above, and their line-ups were always longer, and when elevators were out of service, proportionally worse.
Mr. Isabelle referred to studies that show that 40 seconds is the amount to time that people generally are happy waiting for an elevator to arrive, after which people become increasingly agitated with longer waits, so it is the forty-second mark that he recommends that developers not exceed by much in their proposals. Developers, meanwhile, must contend with not just the costs of building and the returns through sales or rentals, but also with the City's insistence on typical floor-plate sizes. Tower proposals have been getting taller over the years, first to amortize the cost of the land over more units, but now also in response to provincial and municipal mandates to build more densely in response to the housing crisis. Other costs related to materials, labour, and development charges have been increasing as well, so the size of suites have been shrinking, meaning that 11 or 12 suites per floor (and therefore more residents) has become more common. At the same time, the City still wants 750 m² floor-plates in an effort to minimize shadows and allow more light to reach ground level, which discourages developers from adding elevator shafts (and losing revenue generating or returning space). UrbanToronto advocates that developers not be penalized for larger floor-plates that take into account more than four elevator shafts.
.In the case of this building, Angel Developments is proposing 6 elevator shafts to serve 774 suites, or 1 elevator for every 129 suites, a number I characterized as "not great" in the first post in this thread, based on the general numbers we have seen until now…
…but as I said above, for the first time, a developer has responded to our criticism, with something to actually chew on.
Evan Nicol of Angel Developments has been steering the project through its planning process, coordinating the various team members, including talking with Councillor Chris Moise's office. We are told that elevator service is of prime concern for Councillor Moise across his ward (an ever larger, ever-more significant percentage of his constituents live in high-rises), and that for Evan Nicol himself, good elevator service is a particular concern as 241 Yonge is intended as a rental building, and Angel's commitment to the building will not end with handing over the first keys to the residents, but it will continue as they look to maintain customer satisfaction and high rental rates over the years. To that end, Angel engaged Jon Soberman of Soberman Engineers Inc, another highly regarded vertical transportation engineer, to advise them on elevator service for 241 Yonge. Soberman's analysis of the plans is that 6 elevators, travelling at at least 1,000 feet per minute, possibly as high as 1,600, and governed by a Destination Dispatch Control System* (common in new office buildings, but extremely rare in residential buildings) will provide service close to the desired 40-second response time, with times depending on whether the elevators service the underground bicycle storage level (or a separate shuttle elevator is dedicated to that level) or whether the elevators are split across the lower and upper halves of the building, or service the whole building.
More typical speeds for elevators in low-rises are about 100 feet per minute, about 200 fpm in mid-rises, while 500 fpm is consider a minimum for a high-rise, and 700 is typical. 1,000 fpm is considered very good, and above that is rare in Toronto residential buildings. (Even higher speeds are possible: the fastest elevators in the world in the 530m CTF Finance Center in Guangzhou, China travels at 4,127fpm, but that peak speed is reached only in the middle of direct runs from the ground floor to the hotel and observation levels up top.) In any case, higher speed elevators could offer relief for residents of 40 50, 60-storey etc high-rises in Toronto that currently have slow service when the buildings have sufficient funding in their capital reserve funds to replace the motors with faster ones. Destination Dispatch Control Systems, which add cost, could help too. Since Angel is planning for both high-speed and destination dispatch here, then there's no reason for us to object to 129 units per elevator here.
For our part, going forward we will change the way we refer to proposed elevator ratios to reflect that acceptable service will require higher than normal speed motors and possibly destination dispatch.
I may expand this into a front page story in the future (and I'm amending my initial post).
42
*If you've not encountered one yet, Destination Dispatch Control Systems ask riders in input on a touch screen which floor they want to go to before they are in an elevator. The system then individually assigns riders to particular elevators, grouping riders (more so during peak times) by close floors so as to minimize travel times.
Gorgeous so I'll try to enjoy it before the inevitable de-value engineering happens. At the very least, the colour will get watered down to beige and the bands reduced in width till they have next to no visual impact. The rounded bands? No way those will survive. The probability that Toronto will build something this nice is close to zero.
I'd love to be wrong, of course.
42
Great post Craig - appreciated. I've seen Destination Dispatch Control Systems become increasingly common and have wondered about their impacts on response times.
Thanks!
There is a question regarding just how effective Destination Dispatch can be in residential buildings.
As I mentioned above, they're only really in use in office buildings at the moment (new, or retrofitted), as those buildings get more concentrated demand for certain floors at certain times, so having a computer coordinating the cabs during the highest demand times (start of work, lunch time, end of day) can improve everyone's experience.
In residential buildings, the demand is more spread out than in office buildings. Office buildings typically have larger floors with more people per square metre, and a workforce of a hundred or so people that is more likely to come and go within restricted time frames. A residential tower is more likely to have a dozen or two people living on it who all work in different places (including at home) who need to depart at wider times depending on the distance to their destination, and so they come and go at more diverse times. Here, Destination Dispatch is better for sending elevator cabs to a close set of floors (so that every elevator doesn't have to head as high as the 60th storey, for example, at high traffic times: you want to elevators be back at ground level as soon as you can have them there, so it's still better to put people heading to the 30s together, and the 40s together, etc etc., but it won't quite have the same impact as sending 15 people together to the same floor at in an office building all at once.
42
42
Alternatively they may be assuming that their final design looses some density through the planning process. Although their elevator plan could be rationalized on paper, when they have elevators down for maintenance or move-ins their situation will become much worse.
It is possible that they won't get the full height they are looking for here, but I would be surprised if the approval comes with a significant cut, if any.
Every building, of course, deals with elevator down-time, so the more elevators there are, the better to cope with the less than optimal service while one of six is down, as opposed to one of five, or any lesser numbers. I don't know what studies show re: how much patience people generally have in such situations, but I'm sure it wears thin quickly when more than one elevator isn't playing ball.
42
I once rented an AirBnb in la Tour des Canadiens in Montréal, next to the Bell Centre, and it had a destination dispatch system and high-speed elevators. They made an enormous difference, I just could not believe how quick it was.
The applications for this one are now public-facing in the AIC:
We've already got all the renders......so here's the other stuff:
Site Plan:
Ground Floor Plan:
Since the heritage was noted in that last paragraph, I went into the HIA to see what the building used to look like:
There was earlier discussion of the Hospital Flight Paths:
@HousingNowTO will wish to note that there is no affordable housing component mentioned.
An in-person community consultation meeting is being planned for this project on May 27th, 2025 at City Hall:
239-247 Yonge Street25 102468 STE 13 OZ
Abraham Plunkett-Latimer
2025-05-27In-person6:30 p.m. – 8 p.m.
100 Queen Street West
Committee Room 3
Toronto, ON
M5G 1P5
Summary​
This report recommends that City Council state its intention to designate the property at 241 Yonge Street under Part IV, Section 29 of the Ontario Heritage Act for its cultural heritage value according to the Statement of Significance which includes a description of Heritage Attributes found in Attachment 1.
The subject property at 241 Yonge Street is located on the east side of Yonge Street mid-block between Shuter Street to the south and Sankofa Square to the north, in the Downtown Yonge East neighbourhood. A location map and current photograph of the heritage property are found in Attachment 2.
The property at 241 Yonge Street, formerly known as Art Metropole, contains a four-storey mixed-use commercial brick and stone building constructed in 1911 in the Edwardian Classicism style, following the designs of the architectural firm of Mitchell & White. It was purpose-built as the commercial property for the Art Metropole artist material supply company, first established in 1888 as one of the earliest companies of this type in Toronto. Art Metropole played a key supporting role in the artist community of early 20th century Toronto. Research into the products it supplied and who it supplied them to has contributed to a further understanding of that community. The first Art Metropole directly influenced the naming of the contemporary Art Metropole, the artist-run centre established in 1974 by the Canadian contemporary art group, General Idea, at 241 Yonge Street. Art Metropole was pivotal in the establishment of a national network of artist-run centres that connected the counterculture contemporary art movements of the 1970s and 80s. Today, the property continues to contribute to the historic commercial character of Yonge Street, south of Sankofa Square, where its style and typology reflect how the character of Yonge Street has been evolving for over a century.
Staff have determined that the property at 241 Yonge Street has cultural heritage value and meets 6 of the Ontario Regulation 9/06 criteria prescribed for municipal designation under Part IV, Section 29 of the Ontario Heritage Act. A property may be designated under Part IV, Section 29 of the Ontario Heritage Act, if it meets two or more of the nine criteria.
The property was listed on the City's Heritage Register on November 21, 1973.
Development applications for a combined Official Plan and Zoning By-law amendment and a Site Plan Approval application were made with the City for the subject property. The property is subject to a Prescribed Event, for which City Clerk's issued a complete application notice on February 10, 2025. The property owner provided a waiver of the Prescribed Event and has agreed upon the timing of this report.
