The rendering
I think it could end up looking as bad as this
though not quite as bad as this
(Sources Heritage Toronto and ERA respectively.)
I think they did a pretty good job with the Dineen building... It doesn't take away from the original architecture. The same could go for the Bloor Gladstone Library, they did a really good job adding more space while respecting the original building.
I asked myself that same question. Is the tiny addition necessary? Why can't the building just be left as is? Reno the interior and call it a day.
I understand the need to add inexpensive square feet having gone through a few extensive restorations. The costs are comparably expensive and there's almost always hidden surprises. It's unfortunate the addition is so tall/large. Think a simple charcoal curtainwall would also be a better choice.
The one thing that could've been done to the Dineen building would have been to put a curved piece of glass on the corner though... Would have looked a million times better.
Some try to smooth the corners; other cut them.
Regards,
J T
the Gladstone TPL Branch is great, and it hardly touches the heritage structure. Not sure what the complaint is about.
+1 I love the Gladstone library. It is a haven of beauty on that stretch of Bloor.
Agreed.
k10ery, have you seen it live, or only in that photo? Not that the photo is bad, but it doesn't do it justice.
If you have seen it live and don't like it, might it simply be that you're against modern additions to traditionally styled buildings? Ot are there examples of that you like?
42
From the report:
...the owner shall: Provide a Lighting Plan that describes how the heritage property will be sensitively illuminated to enhance its heritage character
Yes please!
Not a huge fan of the addition, but I'll give it a pass because I'm so happy to see this building restored. The addition can always be reclad later.
Agreed.
42
Yes, I see it regularly and have been inside a couple of times.
As an exercise in formalism, I think it is trying to do something but ultimately it fails. The decision to mimic the size and shape of the original in a glass box leaves the extension looking inadequate in comparison. It lacks the strength and monumentality of the original, and it appears unfinished.
This is not just a complaint about modernism or minimalism. A glass box could have worked, if they had done something as simply as extending the original's roof and cornice line in darker coloured glass, for example. But I think a taller, more soaring shape would have been better, as at RCM or National Ballet School.
It's kind of you to ask my opinion, which is after all just some random guy's opinion . I see that it is not shared by many here!
Is it definitely confirmed the addition is glass? Maybe zinc panels like the Porter House Apartments in NYC
The Broadview Hotel addition's exterior expression, as depicted in the rendering, doesn't even seem to take any cues from the heritage building. Even scale of the spacing of the vertical bands seems random and too "heavy". The bands are too wide, there is too little variation, there is no interplay with the heritage component.
And no, I am not saying that it should make literal historical references in its design, but rather it should seek some sort of half-way point with the existing structure, to create an interesting story. i.e. the way the Gardiner Museum plays off its neighbours in subtle ways, especially from the geometry of the UofT building immediately to its north.
