Contra
Does anyone have any pictures showing the intended move? Used to live here and very interested in seeing what this "shift" entails.
they are essentially rebuilding the platform 70 metres further north to improve transfers between the two lines. The south 70 metres of the platform closes, the north end gets extended north by 70 metres, and some new escalators and stairs are punched in.
This is sadly true.And our last vitrolite station is slated to lose all its vitrolite tiles correct ?
All the while without any of the foresight to expand the platform widths...they are essentially rebuilding the platform 70 metres further north to improve transfers between the two lines. The south 70 metres of the platform closes, the north end gets extended north by 70 metres, and some new escalators and stairs are punched in.
Expanding platform widths would require a closure of the Yonge subway for many months, and we all know the city would be virtually paralyzed if that happened. Just take a look at what happens when the Yonge subway is down for 10 mins, let alone months.All the while without any of the foresight to expand the platform widths...
It did not used to be this bad before, but in recent years if there are extended delays at morning rush hour, the Eglinton Station platform gets outright scary.
The shift will help distribute passengers transferring from LRT to the Subway platform
- but won't the shift just create more of a crush from Subway to LRT since you'll have passengers coming from both sides?
(i.e. single ended access would be slower, more controlled access to the LRT platform)
It can use the Spanish solution.
