When it was under construction, someone noticed that there is LED lighting on the bottom. However, this LED lighting has not made an appearance. Anyone know anything about this?
They probably haven't completed that yet it's probably something that will be tied in well they rebuild the entrance underneath it on ground level.
They’re taking the wraps off the new Queen Street entrance.
I guess when you've got the mayor booked in and Black Friday is approaching, you 'finish' the bridge even when it isn't quite finished. You can always nip back in later with your toolbox to finish of the lighting, or that bit of glass that some genius managed to crack on the last day of construction and so on.
Nov 29
Not sure what taking place on top of the office tower, other than expanding the mechanical area.
The Samsung store is slowly coming together. Peeking through the hoarding inside, and then slowly revealing the windows along Yonge over the last few days…
42
I actually really like that big blank Uniqlo wall. Its such a simple and effective way to convey what the store has going for it. Do wish the lighting was a tad less orange at night, though. It's the place for big bright LEDs, (like a red ring around the inset).
The way the Uniqlo signage wraps around it, it will likely look like Uniqlo has a Samsung department. Well done again, CF.
If only they had hired WilkinsonEyre for that corner (starting from the H&M addition all the way to the current redo) instead of just one pedestrian skybridge.
If only they had hired WilkinsonEyre for that corner,
If only they had hired WilkinsonEyre for that modernization of the mall interiors,
If only they had hired WilkinsonEyre for that Yonge Street facade,
If only they had hired WilkinsonEyre for that 1 Below mall expansion,
If only, if only, if only.
