doug
Active Member
I think of they were platinum or steel they'd suit the building much better
Platinum? seriously?
Enclosing a transmission antenna in a metallic/conductive shroud does not work if you wish to continue broadcasting.
I should be more specific. Platinum in color, not in material. That said I wasn't anticipating they'd be shrouded in platinum, rather the antennae would be darker in color. Once again, much like the current set up on 1WTC.Platinum? seriously?
The spire on the WTC is an architectural feature, the broadcast antennas that have been mounted on it are exposed.
They're on the ring below,
You're correct there are indeed some on the "spire" as well.
this is just fantasy and pipedreams so I wouldn't worry too much about the technical aspects.
Similar to the call for burying power lines, most people don't understand the technical aspects and seem to get upset that it hasn't already been done...it's easy isn't it?
Anyways, I feel like no matter what's posted there will always be someone to pipe-in about the technical issues. We're just trying to have a little fun!
