So I'm wondering if they're just referring to completing the rail corridor crash wall (as opposed to the whole Block 20 development) prior to the completion of Block 8.
Aha, that would make much more sense! Good catch.
Looks like the CL was revised and reuploaded. The original version said:
"The proposed development incorporates rail safety measures for Block 20 and are detailed as part of this rezoning application. With respect to phasing, Block 20 is planned to be completed prior to the completion of Block 8. Should there be an unanticipated schedule change, the approved or approved alternative rail safety mitigation measures will be implemented to satisfy Block 8’s requirements."
The updated version reads:
"The proposed development incorporates rail safety measures for Block 20 and are detailed as part of this rezoning application. With respect to phasing, the rail safety measures for Block 20 are planned to be completed prior to the completion of Block 8. Should there be an unanticipated schedule change, the approved or approved alternative rail safety mitigation measures will be implemented to satisfy Block 8’s requirements."
So that makes much more sense.
So .... This is being planned with an alternative scheme to reduce the gap between the building and the rail corridor, at the same time that Metrolinx is drafting top secret plans to run the Ontario line beside the rail corridor across the Don then into a portal where presumably there will be a TBM launch site. Right here. What could go wrong?
A zoom-in and flyover:
I am really curious about that. The routing has to cross the Don north of the rail lines to head north-west eventually to Queen Street. I think they will have to dive under the rail lines' viaduct and turn north on Parliament. There is -some- loading space but there is definitely a conflict here. If they built -under- the Don, they could start the tunnel east of that, but I know they want to build as fast as possible.
Looks like a good fit across from the Distillery District. Not sure if they'll age well.
Event Information: 125R Mill Street OPA/Rezoning Community Consultation Meeting
Date and time:Monday, November 2, 2020 7:30 pm
Eastern Standard Time (Toronto, GMT-05:00)
Change time zone
Duration:1 hour 30 minutes
Description:
125R Mill Street Official Plan and Zoning By-law Amendment - Virtual Community Consultation Meeting
The Province has just issued Ministerial Zoning Orders for these blocks!
https://www.ontario.ca/laws/statute/90p13
Once you open this document, click on the tab titled Regulations. It will bring you to the page where the zoning orders are listed.
O. Reg 596/20 applies to Blocks 3, 4 & 7
O. Reg 595/20 applies to Blocks 17 and 26
O. Reg 594/20 applies to Block 20.
What does that mean exactly.....for the layman out here...
