Montreal metro trains weigh more per unit area than TTC trains because they are narrower. Trains require the same components, and those required components aren't going to change any time soon. I
Montreal metro trains weigh more because they are a rubber tyred metro and therefore have both a set of steel wheels, rubber wheels as well as guidewheels etc. They are much more complex than even the Toronto Rockets.
Perhaps a bad example on my part but you are focusing on the wrong thing; they are narrower but longer and still have the same capacity as the Toronto Rockets.
Their narrow design allowed the Montreal Metro to be a single bore project and thus was cheaper than the TTC tunnels to construct.You could do a single bore for the existing TTC subway system but due to their width the cost savings would be negligible since you would need such a big bore.
One of many ways a different technology than the current Toronto system can be more cost effective.
Who built the Yonge Line?
Who built the Bloor Danforth?
When I mentioned historically, I meant the entire history of the TTC, not just their last project.
Let's not forget from an operations perspective, the TTC is among the most efficient mass transit systems in North America from a financial perspective.
The Yonge Line extension to Finch was delayed a year due to a strike. Maybe they didn't do as badly back then but recently they have a lot of problems with their projects. A simple project like the streetcar tracks on Leslie was installed at an incorrect height that had to be ripped out cause no one decided to check them. You can't blame ML for this one, TTC is totally to blame for lack of oversight. Sure it's not their fault but it did annoy the community for delays. I know there's a lot of TTC love here. I'm not saying TTC can't trusted to build the RL but there are risks too.
The TYSSE was a shitshow but it was still a successful addition to the network and built cheaply considering modern subway construction costs. One also must note that Metrolinx was heavily involved in that project as well, from financing (influencing contractor choices) to design. The last major TTC subway construction project was the Sheppard Subway, and despite the crap the line gets, it was built on time and on budget. The same can pretty much be said for the Sheppard West Extension, the Spadina Subway, and the Kennedy/Kipling extensions. With Metrolinx, Either something is delayed or something imperative is cut (electrification for the UPX, construction for the Crosstown and Finch West LRT). Most of it is likely due to the construction conditions and techniques of today, and the standards we have set for ourselves.
Side note, this line will theoretically be built using the P3 method. This is a recipe for disaster. I can understand contracting out for a new LRT line in the middle of nowhere (ie iON) or a commuter rail service, but not a vital rapid transit project that needs thorough integration with the TTC, not GO.
Now we await the completion of the crosstown to either prove P3 can deliver a project on time or not. We all know ML can't make up their minds which lead to crosslinx suing ML. Hopefully ML can deliver after learning from a few P3s now.
They have the same capacity because station platforms in Montreal are over 150 meters.
It makes absolutely no sense to extend the platforms 20 years after the line is built. The cost and time investment will be huge. I'm not even sure it'll be possible given the route they've chosen and the above ground sections.
100m lengths are being used to save money. Saving money is great, but it significantly lowers capacity. That's the dilemma.
When the Eglinton LRT was being presented there were quite a few pro subway people complaining that the lrt train length would reduce capacity and we should be forward thinking and just build a subway. Today those same people are on here saying arguing that train length isn't a issue. Good luck trying to get people to either admit they are wrong and or change their minds.
I meant the physical track connection. It's a different type of train, so connection is not needed - save some money.
It would still be an interchange station.
So you save money by not building a track, but instead have to spend it on a brand-new heavy maintenance facility which costs more to build and run?
Doesn't seem like the best way to save money....
Just as the Model T Ford was fine for its time. No side windows. No air-conditioning. No mirrors.
From link.
The Tesla Model E would be fine for today or tomorrow.
From link.
The bad news would be that there would be much more parts that could and will break down, and you can't fix it by yourself.
I would support this plan and elevated transit if It meant things like Sheppard subway could be extended above ground. This city has been completely against elevated. We couldn't build elevated to Vaughan. Elevated to stc was shut down. And elevated Eglinton lrt wasn't even a option. So I'll take this plan with all its faults if it can actually get shovels in the ground and get other projects extended above ground.
It's been a few years since I visited, but I seem to remember Tube trains sharing track with commuter/regional trains at several points in London. Wonder if something similar is planned for the Ontario Line/GO rail corridor integration, or if the OL will have it's own elevated guideway next to the tracks as
The business case mentions "cross-platform" (same level?) transfers at Exhibition for the possibility of further western expansion.
How does your station sizing strategy work when evacuating a train larger than the station in which it is located? Or did you just kill 1/3 of the passengers? Just wondering.....
That's a valid concern. However:
- I've seen a few lines in other cities, that do not open all doors at all stations. They probably have some evacuation plans in place, that do not require all doors open.
- TTC has procedures for evacuating trains between stations, with no platforms at all. That's the reason they build emergency exits between stations if the stations are located far apart. In the one-stop SSE design, they have as many as 6 emergency exits between Kennedy and STC.
1) The anti-Fords want to revert to the Keesmat DRL subway.
2) The get-it-done crowd is ok with the Ontario Line.
Likely, there will be ~80% overlap between those two groups. People who would rather see a Relief Line with a higher capacity limit, but will not oppose OL for fear of not getting any relief capacity at all for several more years.
As @W. K. Lis said, Montreal metro trains lack air conditioning. Their more complex driving systems should be offset by the weight of an HVAC unit on each train. If you want to optimize materials (that will, in-turn, save weight), you have to widen trains. This is a grade 8 math concept.
Again, length equates to more expensive stations. The blue line extension is costing about a billion dollars a mile (4.5 billion total, with likely cost increases in the future), which is almost the same as the TYSSE or Crosstown per km of tunnel. Tunneling itself is far more complicated than saying that a single bore is cheaper. It may be, but their tunnels were mined. The real factors that will increase the cost of tunneling are soil type, groundwater pressure, and depth. Regardless of how you build the relief line, you're going to be building really close to Lake Ontario, and you will be building really deep. In Downtown Toronto, the soil is clay, which is somewhat easy to manipulate. In east york, it's sand and silty sand, bad news when building next to a lake.
Regardless, you're not going to be saving money on this project for tunnels, trains are pretty much the same width, and the tunnels will be built downtown, meaning that you need to twin them (Or risk hitting existing infrastructure).
The P3 model for the Crosstown is more acceptable because the TTC would be operating the line (as it should). With the Ontario line proposal, they want a third sector company (say Keolis) to operate and maintain the trains. That just screams zero integration with the TTC, and this is a line that badly needs to be integrated with the TTC.
Quite the dichotomy.
This is the one line where having a fullly fleged, full capacity subway should be the only option.
They wanted fully automated with no one will physically operate the line. Will TTC be given control over the trains or be able to monitor the network from Hillcrest is another question. I agree TTC should be able to dispatch more trains in emergency situations or shut the line down for safety reasons. That's the integration they need. They really don't need to have someone watch if the trains a running properly, that can be contracted.
Unless you're a TTC union's fan, having physical operators on board causes many management issues as they cannot maintain a schedule. All the annoying crew changes would be eliminated as there is no need to maintain a schedule but instead based on headways. Then you also eliminated the PTSD issue when subway operators witness and have to be on paid leave. The operating cost will be even more efficient than TTC having someone onboard themselves.
TTC might be efficiently at recovery cost but I don't see them being efficient with reliability. They more interested in making sure their operators finish their job on time than making trains full of people wait.
Disclaimer: I'm not necessarily against automation, but that doesn't mean I don't support the Union. The relief line would be far enough into the future that Automatic train running would be less of an issue overall for the Union and they'd have less leverage, but their current employees should still be supported.
A lot of crew change issues could be avoided if they moved them to the terminus stations, but it's just easier to perform them at Greenwood, Eglinton, and Wilson.
Most of the delays on the existing subway network are due to passenger incompetence or old infrastructure. I'm genuinely not sure if automation without Platform edge doors will allow for efficient operation, especially on a super busy line like this one. At least with drivers present, they can assess situations far better.
I'm more so worried about integration between the TTC surface routes and the Ontario Line. That is one of the best selling points for the TTC, and Metrolinx seems to be ignoring the legitimacy of this network characteristic (The Crosstown and Finch West LRT come to mind). I live in Waterloo with the iON light rail line, and one issue I've noticed with the contracted out system is that integration with the buses and trains are not timed properly, and not well integrated. This is obviously much less of an issue for the TTC since they have such a frequent network, but it's something planners don't really communicate effectively with each other.
