Oh, I get that. What I don't get is prioritizing that GO crowding relief over Line 1 crowding relief.
Simple - it's Metrolinx.
They have a pretty amazing ability to not see the world beyond the end of their nose. And unfortunately, this has always been the case since GO was formed in 1967. Just about every single action they've ever taken, every single project has been created and implemented in a vacuum, with almost no thought or consideration to any knock-on effects that it might have, or what its implications might be to those around it.
The whole battle of the LRT lines between the number of stations and the speeds of the line are indicative of this. In Metrolinx's eyes, fewer stops means faster service means better - period. There is zero consideration to how people are required to access the systems (we'll put more parking lots in!1!), or how the systems will integrate and operate with the existing environments (bigger bus loops!1!).
Also, this plan neglects Parkdale and High Park.
So? Why would Metrolinx care about those neighbourhoods? They don't take the GO train.
True, but it still goes through queen does it not? Why not just take the DRL plans, stick with TTC rolling stock, and come up with a plan through union. No point in making people walk 10 minutes.
First off - walking 10 minutes? What?
Second, the DRL didn't interface with the GO lines, at least not in a meaningful manner that would have substantially offloaded any capacity from the inbound GO trains. Also: It was the TTC's plan. Metrolinx needs to show that it can come up with better (erer?) plans than the lowly TTC.
I mean walk 10 minutes from king street (where the Ontario line stops will be) to Union. The rest of your post, I agree. And it's sad.
I guess you mean for people who work around South Core?
Probably no different than all the people who get off GO trains at Union and walk 10 minutes to the towers at King & Bay through PATH. I suppose, however, that may set up a counterflow in the PATH (like salmon swimming upstream).
I suppose they could catch the streetcar at Spadina down to Queen's Quay.
Because there are a lot of people who work downtown and take the GO train into Union who aren't a 10 minute walk away from the station.
I can't seem to find the numbers right now, but there's a very substantial portion of commuters (or at least, there were prior to March) who get off of the GO train and take a subway north to their destination - but from memory it's approaching 20% of GO's ridership into and out of Union. If they can offload those passengers from the GO system away from Union, that would go a long way towards helping limit the impending crush.
But if the goal of most of these people is to go North, then why would they pick the Ontario line? At Union you connect to both the Yonge Line and the University-Spadina line, without having to transfer twice. If the Ontario line went to Sheppard it'd be a different story, but it's not. If people are going north, a better option would be the increased utilization of the Barrie and Richmond Hill lines, with more stops and better frequencies/connections.
The Ontario line only seems to benefit users if they're going to a location along Queen street or to Corktown. Transferring at Exhibition or East harbor is going to suck a lot more than Union given the lack of amenities and space. This would be especially true for people going to Hamilton, Kitchener, Barrie, or along the Milton/Richmond Hill lines, where wait times can exceed 30 minutes. If you're going down King, there is some benefit to this arrangement, but it's not particularly more beneficial than the current arrangement or the RL arrangement.
All good points. I'll also add that, from the east, the limited capacity of the Ontario Line limits whatever potential (if any) it has to relieve congestion on the GO lines coming from the east side of the city. Why leave a crowded Lakeshore East train to attempt to pack onto a crowded Ontario Line train that might be too full to even fit you? Further, extending the Ontario Line north to Sheppard would render moot this GO relief exercise, as the line would overcapacity south of Bloor
Because they're only going as far as Bloor in almost all cases, and most no further than Dundas. A line intercepting the GO lines and running under Queen would likely capture a very good quantity of those commuters, as they could then walk from Queen to their destination.
Sure, those that are traveling further north aren't going to make use of the Ontario Line, but they're such a small proportion that it would be churlish to try and cater only to them with the line.
Yes - that's the point.
I'm not sure how you could come to this conclusion considering that there are simply no designs to make assumptions about.
You're making a lot of assumptions here on things that either won't hold true if the plans continue to unfold, or on things that frankly none of us know about yet.
Well, this is the $64K question, isn't it? If somehow the line does everything that it promises, than capacity won't be an issue for quite a long time. But what if it doesn't?
Looking at East Harbour, the transfer is going to be seamless based on the description provided so far.
When taking a GO Train downtown in the morning from the Stouffville or Lakeshore East lines, you will get off and literally cross the platform to the westbound Ontario Line platform. It will take literally a matter of seconds, especially if the Ontario Line is running at 90 second frequencies.
In the evening reverse it.
Transfers will be a bit different and longer if you want to do something else, like go north on the Ontario line, but for most people it will be seamless.
If you work in the north end of the financial district, basically anywhere north of King St, making this transfer will likely be faster and more comfortable than walking from Union Station.
Not sure on the design of Exhibition, but hopefully it's similarly very easy to make the transfer.
I can see an increase of ridership going north to the Ontario Science Centre.
Based on my conversation with staff at Metrolinx during an Ontario line open house, the line will probably be as follow:
Westbound OL arrives next to westbound GO,
Westbound OL dip underground
Reverse direction
Eastbound OL raise above ground, arrive next to eastbound GO
Again, everything is subjected to changes.
Latest post.
Too bad the "experts" at Metrolinx aren't asking the "experts" at the TTC. But then the TTC doesn't know much about building rapid transit lines. Oh, wait a minute...
The current Ontario government still thinks that development by the private sector is the best way to go. Using long-term care as their example, we can.... oh, dear. We're in trouble.
The developers arent the ones to blame on LTC. They just develop the land into the facilities. Its the ones who own and operate it that are responsible for this mess.
TTC really can take a page as well from the rest of the world. They continually advocate the message that tunneling is the best way to do things here and their stations must be gigantic mausolems (a la hwy 407 stn). Not to mention the management of their spadina extension is borderline criminal in terms of negligence and incompetence
Citing Vancouver and Chicago as successful examples of elevated rail annoys me. I'd say the reason it generally works in Vancouver is that it goes through industrial areas or commercial area's (with density at stations). So that may or may not apply to Toronto in certain areas.
