idc24
Active Member
This looks incredible! Reminiscent of the great airport railway terminals of Europe and Asia like London, Amsterdam, Paris, Hong Kong and Tokyo.
Regardless of branding, that's an incredible convergence of services at a second different location than Toronto Union.The sign indicates that the Line 5 Crosstown, the Line 6 Finch West and some kind of rapid transit service built in the express lanes of highway 427 will be all branded as 'GO SmartTrack' when the commence operations in 2021 and 2022. So maybe the two centre lanes of the 427 will be converted to railway use in the 2020's at some point. By that point the TTC will probably extend Line 2 to a new terminus at Cloverdale to have a direct connection with the 427 rapid transit.
Toronto Pearson said:Relying on Regional Airports
Southern Ontario is fortunate to have many airports to serve aviation demand. With the growth that’s coming, the aviation pie in Southern Ontario is only going to get bigger. If airports work collectively to manage this growth, there will be economic benefits for the entire region.
Swear?I don’t think I want to fly in a plane run by an airline called Flair or Swoop. Maybe they need to merge and call themselves Flare & Swoop.
I still disagree with having security screening (i.e. passport control in the referenced image) at the transit centre.
This means bag drops happen there as well and the luggage processing system would be caarying bags all that way. Lot of opportunities for break downs.
Just leave the security screening at the orignal terminals and build a multi modal transit station.
-- Eglinton Crosstown LRT
-- Finch West LRT
-- UPX
-- Trains/HSR to Kitchener/London/Union
-- Car sharing
-- Buses
I think it will take till ~2031+ (or even 2040s) before all of these services converges here, but the planning certainly needs to protect for that eventuality.
This could be tomorrow's reinvented Malton GO, assuming a high-speed LINK II people mover (or even using LRT as the people mover -- connecting Finch West and Crosstown together with the core section becoming a fare-free-zone peoplemover).
Also, I hope Hamilton stays on the ball for the A-Line BRT plan to YHM. It also makes it a simpler two-hop between the two airports.
Hamilton already has its own equivalent of UPX: The new Pearson 40 express GO bus with an interim stop at Square 1, departing every 30 minutes.
That said, I hope (once Greyhound abandons the route), that Metrolinx eventually have a north-south Kitchener-Cambridge-Hamilton bus route. We shouldn't leave YHM out as a relief airport option, nor deprive Hamilton of access to the other tech hubs. YHM should be fully utilized long before Pickering Airport gets built. Even Pearson professed to such importance of connections.
What happens to the giant car parking garages when the transportation hub opens? Will they be redeveloped and moved/rebuilt underground?
If designed properly, I think that one central point for check-in and security screening could work well. It would have the added advantage of making all of Terminals 1 and 3 secure zones as well.
Also, IIRC, the images released last year showed the current check-in area of Terminal 1 being re-purposed for additional gate space. A central processing facility in the Ground Terminal would facilitate that. Check-in, bag check, and security at the Ground Terminal, with US Customs Pre-Clearance at certain areas within T1 and T3.
That's the largest parking authority garage in Toronto!The largest underground parking garage in Toronto is underneath City Hall
Thought It might be neat to collect a list of the largest parking lots or garages in the city.
The largest I've found:
1. Toronto Pearson - 15,600
2. Canada's Wonderland - 10,300
3. Square One - 8,700
4.Yorkdale - 8,200
5. Vaughan Mills - 6,300
6. Scarborough Town Centre - 5,796
7. Markville Mall - 5,170
8. Sherway Gardens - 5,161
9. Promenade Mall - 3,595
10. Pickering GO - 3,600
11. TTC Finch Lots - 3,227
12. Clarkson GO - 3,000
13. Erindale GO - 2,201
14. Toronto City Hall - 2,087
15. Green P 2 Church Street (st Lawrence garage) - 2,008
16. MTCC - 1,700
17. TTC Wilson Lots - 1,602
18. TTC Kipling Lots - 1,465
19. Oakville GO - 1,400
20. Enercare Centre - 1,300
21. TTC Kennedy Lots - 1,135
22. TTC Islington Lots - 1,087
23. TTC Warden Lots - 1071
Rules:
any collection of public (anyone can go and park there, so not condo garages) parking garages that have over 1,000 spots within the GTA. Malls, GO stations, etc. all count, as long as there is a source for the number.
How would US pre-clearance work? You need separated entry/exit points from the security to the gates. Plus a way to move in/out of the US gates when transferring planes.
This is why I can't figure out how this would work.
Plus when I have to fly somewhere for work I don't want to spend 15 minutes walking to get to a gate. It'll drive people to the Island Airport.
