Great front page story - helps put it all in context.
@Northern Light - what do you think would fit in the proposed park? It looks sizeable, but will probably be the main park for not just this development, but the whole future surrounding neighbourhood. I think my ideal would be to have a soccer field in the north portion, and have the south portion shared between a playground and a fenced off-leash dog park. Could all of that fit? What would you envision?
The park is not nearly as large as you may think. It's proposed as being only 0.5ha or 1.25 acres.
As proposed, (so excluding any abutting City lands) the proposed park is not nearly large enough to hold a regulation soccer pitch.
Crudely drawn, the park's length along Benny Stark appears to be ~84m, that's the long side of the park.
A soccer pitch by regulation is 105M by 68M. (0.7ha or roughly 40% larger than the entire park!)
So there just isn't the room.
You can made an under-sized one for kids, should you wish. A pitch doesn't have to follow FIFA rules!
From Wikipedia:
For reference, I have crudely drawn an approximation of a regulation soccer pitch over the lands in question.
As you can see, this could not only consume the entire park, but also the City's EMS Station and a few adjacent homes!
It could be made to work, but other than substantially reducing the size of the field, the EMS station would have to go, and you would need some additional land either from the proponent or adjacent owners.
The City will accept a regulation field as small as 100 x 64 which make it a bit more workable. But kiddy fields (mini-pitches) can be as small as 31m x 67m. That would definitely fit.
Turnberry North Park is actually an ultra-mini, or soccer for pre-K! LOL
It's only ~22 x 35. If you want those, we can put in two, no problem!
As to what belongs in the park, I think that obviously depends on what locals want, what's available,and how much room is left after you insert your highest priority.
Given that there is no Children's playground going all the way north to Rogers Road and East to Old Weston Rd; that would seem the most logical priority.
A decent sized play area, with water play, will take up about 0.3ha/0.75 acres. A DOLA (Dogs Off-Leash Area would ideally be of similar size).
That means you could really only get one of the two, without significantly expanding the park.
This is a park based on the proponent's space, plus the north portion of the EMS site and the existing Turnberry Park:
That configuration is 0.8ha or 2 acres.
You could probably squeeze a playground/waterplay, a small'ish DOLA, and the existing super-mini soccer pitch on that........just barely.
Given that this area has low parkland levels, I think, the City should not be shy about buying some additional land here. That could either be at this site or another nearby.
