jibsta
Active Member
i guess they are using central area as staging space for now... will probably get things up several floors b4 they slip form the core.
And I think the next set of columns will be thinner/less dense:It's about time for a steel delivery. They're only a couple of weeks away from "topping out" the current columns...
I can't remember the certain height but there will be booster pumps as the tower climbs, since the pumping pressure from the street will drop with the height. I believe when I was on the project we calc'd that just to get to L85 there will be a float of 1 or 2 truck loads of concrete in the cycling in the pipes just to keep them wet, the pressures will be crazy. I think we planned 3 lines just incase as well, not sure if that is still the caseThanks drum118. The pipe was originally placed above ground along the alleyway curb. It was later covered with concrete. When I noticed it was gone I assumed it was removed because the pump isn’t able to push the cement any higher. I didn’t realize the pipe was simply buried deeper. Anyway, it was a roundabout way of asking how high up can cement be pumped? There must be a limit??
Interesting figures from Mizrahi Developments recent Linkedin post:
Original post: https://www.linkedin.com/posts/mizr...=linkedin_share&utm_medium=member_desktop_web
5 jaw-dropping facts about The One in Toronto...
FACT 1: 4300 MT of structural steel (that’s the equivalent in weight
to 700 elephants) was used to build The One.
FACT 2: If you laid the 7200 MT of rebar, used to build The One,
end to end, you’d have enough material to wrap halfway
around the Earth.
FACT 3: 130,000 MT of concrete, which is the equivalent to
8900 concrete trucks, was used to bring The One to life.
FACT 4: The One is the first TMD in Canada and it’s designed
for total residential comfort.
FACT 5: Canada’s First Supertall building and the tallest building
ever constructed in Canada since the erection of its predecessor
in 1975 (43 years ago).
I'm pretty sure they're Toronto-sized rat traps.Anyone know what those gaps are for? I don’t remember seeing anything in the arch plans for this.
This is off topic but do we even have rats in Toronto? In all my considerable time in the city I have seen mice in old apartment buildings but never seen rats in Toronto.I'm pretty sure they're Toronto-sized rat traps.
