karledice
Love the red bricks
No, construction of any kind is almost always preferable to be done during the spring, summer and early fall. But the timing doesn't always work out.Question to experts: Does glazing have to be done in the winter? Is it to do with the expansion/contraction of the material? TIA!
So knowledgeableThere's sometimes a push to enclose certain sections of a building before the winter, but it's usually not necessary. The bigger weather concerns for glazing are wind and moisture. It doesn't take a lot of wind to make hoisting dangerous, and any surfaces to be caulked need to be basically perfectly dry (so rain and frost are problematic). For small sections of caulking you can use heat guns or tiger torches to dry things out (depending on how it'll affect the surface finishes), but it's usually easier just to shut things down if there's a steady rain going on.
