rbt
It's just not reasonable to to expect to study every potential permutation of spaghetti on the map to be studied
I'm not sure why not. Genetic software algorithms for exactly this kind of thing are quite common and pretty standardized (I do this kind of thing for a living at the moment; analysis of big data in unexpected ways to find unexpected patterns). It's the equivalent of throwing things at the wall to see what sticks, but really fast and in really large numbers, then tweaking what stuck to make it stickier.
If a very basic calculation of a route can be performed in a few minutes, it's perfectly feasible to run 1 Million combinations over a couple weeks month including on Amazon's cluster for around $20G's. Metrolinx is asking for $3B, a $20G investment is a pittance.
You take the best ones and do a full evaluation by hand.
Why not complain about the ECLRT EA not considering a rail corridor alternative? Trains could run down the Don Valley, through Union, then up to Mt.Dennis! It's pretty much exactly what you're proposing but rotated 90 degrees.
Oddly enough, I kinda have indirectly. The money being spent on Eglinton is sufficient to put 10 minute frequencies on most GO lines including numerous new bus stations for TTC and other agents to siphon buses into. This would have immense impact across the entire region and significantly decrease East/West demand on Eglinton and numerous other streets.
Eglinton has few destinations. It's just a convenient corridor to get elsewhere. GO lines could be convenient corridors too.
Miller had no control over GO's priorities and just picked items from the reports Lastman requested about streets which were at capacity. Pretty reasonable for his administration to not propose something like that.
Metrolinx, however, was not only supposed to avoid politics and use business principals for planning lines but have the skill-set and authority to implement them. I'm not impressed with their actual results at all.
Anyway, Eglinton and the Yonge extension will both be great and heavily used.
