ShonTron
Moderator
The ghost bus station, to be precise. From May 7 to August (perhaps longer!)
The TTC, in its infinate wisdom, has decided to make repairs to the worst station in the system, Wilson. The upper deck of the two-story bus terminal will be closed for repairs, and those routes (29, 96/165 West, 120) will end up at the north terminal, which has been closed since 1996 when Downsview opened.
Here's why this is so stupid:
The bus terminal at Wilson is way overbuilt for the services that use it, though many years ago had a lot more service, and the north terminal was actually needed because of all the service that ran into there. Budget cuts (ie the elimination of routes like 3 Ancaster Park and 163 Rustic) and the opening of Downsview have reduced the need requirements drastically. Both levels have 10 bays each, for a total of 20 bays, minus the closed north terminal. But this is the layout:
Lower Level – West side (from south to north)
- Vacant
- 104 Faywood
- 96/165 Eastbound (all branches)
- Vacant
- Vacant
Lower Level – East side (from north to south)
- Vacant
- Vacant
- 7A Bathurst (Rush hours only)
- 160 Bathurst North
- Vacant
Upper Level – West side (from south to north)
- Vacant
- Vacant
- 29 Dufferin
- 120 Calvington (rush hours only, every 60 min)
- Vacant
Upper Level – East side (from north to south)
- Vacant
- 96 Westbound (all local branches)
- 165 Westbound
- 96E
- Vacant
Therefore 9 out of 20 potential spaces are wasted, but does a bus every 60 minutes at rush hours need its own bay either?
The TTC probably could fit all the routes on one level on a temporary basis, at least in deference to the elderly or those with mobility issues (not those requiring walkers or wheelchairs, as Wilson is a maze of stairs and escalators, and no elevators!). Even worse, the TTC is going to maintain a terribly overbuilt station (and I am sure expensive to maintain) that will eventually have to be made accessible (all but the 104 and 160 are accessible routes with no access to the subway at Wilson). Why not just build a modern one-floor, 10-12 bay terminal? There's plenty of room on the sprawling lands. They could even just expand the current lower level and demolish the upper section and north terminal.
- Vacant
- 104 Faywood
- Vacant
- Vacant
- Vacant
- Vacant
- Vacant
- Vacant
- Vacant
- 29 Dufferin
- Vacant
- Vacant
- 165 Westbound
- 96E
- Vacant
