drum118
Superstar
The drop down menu for search and quick links is being block by the add and this applies to all browesers.
Anyone having a problem with this on Macs?
42
Or install Safari on Windows.Nope. Everything is fine on mine.
So people... If you want to use the search feature, buy a Mac. Thanks.
It works fine on Firefox on a Mac too. So is it just Internet Explorer on Windows that it does not work with? And which Windows, BTW?
42
To edit an existing HTML page, add the WMODE parameters to the HTML code.
1. Add the following parameter to the OBJECT tag:
Code:<param name="wmode" value="transparent">
2. Add the following parameter to the EMBED tag:
Code:wmode="transparent"
If you prefer to edit your HTML by hand, there are two areas you need to tweak:
1. To the Object tag, add the following parameter (opaque is shown as an example):
Code:<param name="wmode" value="opaque">
2. To the Embed tag, add the following attribute:
Code:wmode="opaque"
.no wmode set
