I think the other two are fairly different in design, at least as seen in that ground level rendering posted a few days ago.
The more buildings blocking Bromley, the better!
Hey I don't mind it's "Fisher Price tape recorder" design
Internal demolition of the Transalta Building appears to have started. The Riddell Kurczaba building should be ready to go down any day now.
The entire block is now fenced off except the proposed office conversion in the SE corner. The Lil park at the corner of 1 and 12 was open yesterday. Must be close to structural demolition.
i know why i could not locate this thread from map, the province was wrong. could we change it?
The province is wrong with most of the projects. That said, I am able to see it on the map just fine.
Are you starting with the Calgary map? Navigating to Calgary from one of the other project maps will not work.
Sometimes the system doesn't take the proper address and append the correct province for some reason. If you know of a project, but don't know its location it should show up to the correct location if you click on the project.
and then about half way down you'll see the map and then you can click on it.
Haven’t been active here for awhile, but damn some high density proposals for the Beltline. This one’s all fenced off now. I’m assuming they wouldn’t commit to demolish the big office without wanting to proceed with the entire project at once?
Hopefully that’s the case, although the transalta building has been largely deserted for years so who knows.
Haven’t seen you around for a while, nice to see you back.
Thanks Ajx!
Walked by here today, looks like a lot of the interior demo has taken place on most floors.
11 ave could be looking solid if this and the two Truman projects are built.
