    Votes: 62 70.5%
    Votes: 22 25.0%
  • Cancel it altogether
    Votes: 1 1.1%
  • Go with a BRT solution
    Votes: 3 3.4%
The problem is that then necessitates the red line tunnel/capacity improvements decades earlier, which is likely in the $2-3 billion range now, as you identify.
There is no world where the red line tunnel does not suffer from the same contractibility problem as the green line tunnel.
I would argue the scope of work with the 8th Ave Subway is just underground work vs the whole starter phase of Green Line.
That the overall project risk would be lower with 8th Ave Subway so it would be cheaper per Km than the Green Beltline/DT Tunnel.
Doesn’t include the various station rough in’s that were planned and built on 8th which would further lower costs.
Red Line Tunnel would see 4x more users go through it than the Green Line Tunnel would opening day.
This would only be matched once we drop another $8 billion to extend Green Line fully.
The SE has low service/capita and is the rationale for the Green Line to the SE, but is that under-served relative to demand, or are SE residents simply less interested in using transit?
The immediate need argument comes from early Green Line related documents.
The 2016 Green Line Business Case document also expected that ridership will be higher in the North; off-peak frequencies would be twice that of the SE.
Now compare that to the 2020 Business Plan and current LRV order. With only 28 LRVs on order, it looks Green Line SE will just have 8 minute peak headways and peak hour capacity will be less than half of the 2016 plan.
Converting drivers to transit users is always a challenge, and using very expensive rail to try do so often results in disastrous results (as seen in the US). A great quote I saw on another forum regarding LRT is that "LRT is the solution for heavy bus usage, not low bus usage". There's a big spectrum of improvements that can still be done in the SE between what it has now and going directly LRT.
The challenge with relying on 2016 analysis is that Calgary was just hit with an oil price crisis. Population growth was fairly muted from 2016-2021, which has skyrocketed in the last few years and the SE area has pretty high suburban density, with stacked townhomes and condos. The deep SE areas are designed with cars in mind (large roads, many stores inaccessible by walking) and it's probably not going to have great all day ridership, but improved transit connections will take cars off the road during rush hour, events, etc. and allow more people affordable access to employment centres.
Despite the growth, transit congestion still seems less than before the 2015 crash. It felt worst around 2007, just before the GFC and major sections of Stoney opened
Deerfoot volumes:
between Southland and Andersonbetween Anderson and 24th Stbetween McKenzie Lake/Towne Blvd and Stoney
2012151,000127,00084,000
2014153,000146,00091,000
2015153,000150,00094,000
2017147,000147,00086,000
2019158,000146,00093,000
202254,000106,00080,000
you can really see how Deerfoot dependent the communities are, with far more minimal pandemic related drops.
I think underground is the only real option for the Green Line downtown. Surface or elevated just aren’t feasible. If it can’t be underground I say don’t do it at all.
But if they spend so much money doing underground and have nothing left for the Centre N and Seton extensions for 20 years, is it even worth doing the line?
Anyone else worried they never released the June budget update?
I was wondering about that also. There is a Greenline Board meeting on July 4th. Verbal progress reports will be given, then confidential ones as well that will likely contain more details (not that we will know):
Anyone think it is a good sign for the project?...
It sounds like July 30 is the day of reckoning now:
Yes. Because, well, financing doesn't work like that.
I'm sure in 1990 it felt like the sprint to finish lines and expansions for the 88 Olympics left the city in a similar situation, yet Canyon Meadows opened in 2001.
Costs have escalated far faster than inflation, so the situation is miuch different.
The Green Line looks to be a hot topic for the upcoming provincial election.
UCP calling the Green Line the Nenshi nightmare
Nenshi blaming the UCP for the delays
If the province wants to Metrolinx the rail system I guess why not.
but yeah, plenty of blame to go around.
I feel like all of these things can be true at the same time:
- What we were promised in 2015 for $4.5 billion isn't close to what we are getting and that's a piss off.
- There has been far too much delay and politics on what should be a straightforward transit project.
- There is plenty of blame to go around as over the last decade a ton of politicians and Admin staff have had their hands in the Green Line pie and still haven't been able to deliver.
- Inflation and other budget pressures means this project has gotten crazy expensive but so has pretty much every other rail project in North America.
- After years of evaluation and considering the various options, the Green Line plan we have now is the best long term plan for Calgary.
- We still need the damn train and are tried of waiting so politicians can point fingers all they want, but they should figure out a way forward to start building the plan we have instead of going back to the drawing board.
Are you sure about these ones? What makes you say the plan we have now is the best long term plan? Or, is it the plan we have now due to path dependency and inertia from a whole bunch of poor decisions made 8-10 years ago?
