    Votes: 66 66.7%
    Votes: 29 29.3%
  • Cancel it altogether
    Votes: 1 1.0%
  • Go with a BRT solution
    Votes: 3 3.0%
It brings me back to the point that we're not really maximizing the opportunities that a low-floor tram presents...because it turns out it doesn't really make great transit? But it sure looks neat in Portland and Bilbao!
Can you name a city anywhere in the world that opened a high floor LRT line (that wasn't connected to a legacy system) in the past decade? The past 25 years?
What do you see as the main advantage of using last century's technology -- having to build larger, more expensive stations or having to custom-order bespoke trains rather than standard models?
Are we going to be waiting until 2027 for a decision on the downtown though? I doubt the (elevated) Events Centre station plans wouldn’t be solidified by then.
I think 4th Street SE (I refuse to call it Grand Central until Grand Central is anything other than an idea is some people's heads) might have to be elevated. Looking at how they've divided up the line, the section that is closest to the station is an elevated guideway. Maybe there's space to run the line down to street level? Could also do so after the station? I recall Grand Central not requiring the same clearance as Sunalta but I'm forgetting why.
All LRVs are bespoke. Calgary has a large enough fleet to not have scale issues even on relatively small orders.
Low floor LRVs are more complicated, more expensive, and lower capacity.
The station size savings (no ramps) you have the tradeoff of longer trains.
Low floor LRVs are great. But they aren’t the best for every application. Ontario uses broadly similar models as trams, on street LRT, an attempt at Calgary style LRT, and automated rapid transit.
Toronto had the SRT (high floor SkyTrain), which is gone, and now they're building the Ontario Line, which I think is going to also be a high-floor light metro?
They kind of look like the REM vehicles in Montreal: https://www.metrolinx.com/en/projec...line/what-were-building/trains-and-technology
Automated or not is what the green line decision should have always been about. It's shameful how the city and council mislead voters with a false dichotomy of two systems that provide lousy service levels and high operations costs as some sort of relevant choice.
Wouldn't bother me in the least if the Spanish trains the city ordered fell off the ship and sunk to the bottom of the sea. They'd make for some great scuba exploration!
With lower platforms and a tighter turning radius, the benefit of low-floor LRT is that it can integrate well into an existing streetscape. For the NC portion of the Greenline a low-floor LRT is perfect.
However, the SE LRT has long sections where it's runs through industrial land and where it runs parallel to a heavy freight corridor, so you kind of lose the benefits of a low-floor LRT.
The benefits of a high-floor LRT is:
-Higher Speeds
-Higher passenger capacity
-Easier maintenance (Motor and chassis is more accessible)
If designed properly, a high-floor LRT system is very beneficial as it acts like a 'Dollar Store Metro system'.
The REM in Montreal is a high-floor LRT that has overhead catenary lines. The first line opened in 2023.
2023
I favour automated, particularly for the north. Wouldn't the Canada Line be an answer to your question?
I do think high-floor for SE might have been a better value proposition for the whole system if it facilitated/prompted some of the following:
- build 8 Ave subway for red line (would have lined up perfectly with Art Commons and current Stephen Ave project)
- build underpass for the green line to get to 7 Ave via 5th St SE (duplicate or in conjunction with 6 St underpass)
- which should mean more money to get going sooner with fully automated north line and/or build further to the SE
Lots of tradeoffs to consider, but the key thing is it would have set up better timelines to actually get the ball rolling. SE was supposedly close to "shovel-ready"; 8 Ave subway would have probably taken a bit longer, so maybe we end up with a few years where red line south terminates at City Hall (or hopefully at least down to 2nd St) while the other 4 lines run on 7th. And North Central would have had the longest lead time.
I'll turn it around and ask what city has built anything like Centre St recently? Some stretches of Edm's Valley Line? Generally less dense and they opted for just 500m of tunnel to climb the hill before running at-grade in DT. Do they have plans to extend further west at-grade?
Portland's E Burnside St looks very similar; built in the 80s but still looks like lower density than we have today on Centre. Their westside line from the 90s also has a similar stretch at the far outskirts. Looks like everything else they've built has had more exclusive ROW (like what we've typically done)
Guadalajara, Mexico, with the current construction of Line 4, not connecting to the other 3.
Guadalajara Line 4 is more akin to the aforementioned Montreal REM and leans a lot more towards the light metro category than the kind of HFLRT we have.
But I do think the Red Line should one day be upgraded to a higher standard with open gangway trains and automation but fwiw, Green Line will also take advantage of CBTC at least in the southeast
That's a good one; I'd call Guadalajara Line 4 light rail (Montreal's REM is not). And maybe Guadalajara knows something (or maybe something is present there) that isn't in Sydney, Paris, Madrid, Taipei, Toronto, Dublin, Lyon, Bordeaux, Utsunomiya, Porto, Tel Aviv, Seattle, Helsinki, Rotterdam, Edinburgh and so on and so on.
Sure, nobody builds passenger trains on spec. But that doesn't mean that using models that are built globally by the hundreds doesn't give us access to better bids that aren't there on models built by the dozen.
-Higher Speeds
Low floor trains can travel at the same speeds as high floor trains, and they have the same passenger capacity as high floor trains. (The low floor trains for the Green Line have a much higher passenger capacity than the existing high floor trains, but that's because they're longer.)
I can't speak to maintenance, only to note that internationally it sure doesn't seem to be a big issue since low floor trains are selected in the vast majority of contexts. At some point, hiring two extra mechanics is cheaper than paying the extra capital costs of high floor LRT.
And there's no logic in saying that the benefits of low floor LRT don't apply to one half of the corridor, but will to the other half -- so we shouldn't use it. If it provides benefits, and no significant drawbacks, then use it.
The 'dollar store metro system' comment just baffles me. What drives cost are things like contracting model, speed of construction, cost of right of way, and cost of right of way structures. What provides the main benefits are protection of right of way, stop location and stop frequency; how high the train floor is does not matter to the core costs or benefits.
We built our initial LRT cheaply and we did it using high floor because low floor LRT hadn't yet been invented, and because the designers had a massive fear of pedestrians interacting with the tracks. The former has been solved and the latter was a mistake -- arguably only knowable in hindsight, but something we know today. We would not benefit from throwing away everything we and a hundred other cities have learned in the last 45 years, even though we did a pretty good job back then.
Building light rail that stops frequently where it is not needed is sometimes associated with an 'urban' approach to light rail that I think compromises the service. I'm thinking of the Valley Line in Edmonton -- especially the next phase, where the train will stop every four blocks all the way to 124th, and it will be painfully slow entering the downtown. (I'd also point to Holyrood and Strathearn on the existing line as being too close.) It's difficult to do that approach without low floor LRT, but picking low floor trains doesn't condemn you to this approach.
Building slow trains that stop every couple of blocks and are in mixed traffic is not a good investment (unless it can be done very cheaply). But a good LRT line that provides fast access can be built with either low floor or high floor vehicles, the difference is mostly whether we want more accessible and cheaper stations or not.
I'm not 100% sure what you mean by "like Centre St". I assume at grade, in the median of a road? In the Rainer Valley in Seattle along MLK. Canberra on Northbourne Road. University Ave in St. Paul Minnesota. The north end of line 1 in Guadalajara. Avenida Dels Tarrongers in Valencia. Boulevard Etats-Unis in Lyon. There's only so many places that have a right of way wide enough to handle both as well as a psychological need to retain both.
better bids
The problem with that logic is low floor LRVs are just inherently more expensive all other things being equal due to complexity.
Often that is worth it if you have significant street level sections. With significant street level sections constraints already exist on operations that make any constraints the vehicle is creating for operations less of an issue.
Arguably on the low floor list Ottawa and Seattle both made the mistake of going low floor due to initial preference and not reevaluating later when system design evolved way past the initial vision. Add Toronto to that mix but a different flavour of it.
Toronto is weird since the local union hated ALRT/Skytrain/automated light metro to such a degree they killed an existing automated line after hobbling it with operators for decades. So worried they were about retaining 2 person operation on their legacy network. The local union even forced itself onto the Eglinton line’s LRVs which effectively was the thing that killed the ability to run the project as a P3. Another goal of the union was to kill P3 as Toronto had a very cosy union cost based contracting system where the TTC acted as their own general contractor. The Toronto project also evolved from a surface level vision that they were going to build for cheap (they even forgot to account for: utility relocation, maintenance facilities and vehicles in the original high level estimate) which seems to be a common original sin of Canadian projects. Eglinton didn’t warrant the high capacity that a full scale Toronto subway would provide. They also wanted to avoid the massive stations and sterile bus transfer facilities that the TTC insisted on when it built subways.
So Toronto ends up with a LRV underground through the parts of the city most suited aesthetically to street running. Then at grade in the middle of a stroad. They were also sold the myth that integrating signalling between street running and automated tunnels was easy.
Toronto is weird
Agreed
Impairing safety and efficiency with outdated methods and technology when better options were available sounds pretty close to fitting Canada's definition of sabotage...
Sending those involved with such decisions for a decade long all expenses paid retreat to camp sunshine might help induce some more holistic planning attitudes.
Thanks. By "like Centre St" I mean at-grade down a relatively narrow ROW that is the busiest bus corridor in a city. I really appreciate the examples though and look forward to some street view exploration (particularly Valencia because I spent a couple weeks there 20 years ago). Quick follow-up question: how many of those went to absurd lengths to grade separate a long section of track?
We always end up on the LF vs HF debate, but the complaint is really about the incongruity of the whole design. LF at street level is totally fine - especially if the ridership case isn't a slam dunk and you don't need to max out frequency. It's also great to invest in as much grade separation as possible - especially if the ridership case is really strong and it lets you move lots of people efficiently.
But our qualifying statements are reversed and we're spending silly money to facilitate compromised design without reaping substantial benefits (certainly not the degree we would with 8 Ave subway or fully automate north line).
You've gotta admit It's a bit funny that at one point or another we've planned for all eight stations between 16th north and 26th south to be expensively grade separated.
