haltcatchfire
Good job. You’ve replaced a mall…
… with a strip mall.
I still think it sucks. It looks like something I'd expect to be built in Airdrie.I feel like this is a good kickstarter for a more dense node. Now that this will be buildt, more developers can use that area to build more around the area.
And it’s not that close to an LRT station
I’d rather see stations at at Northland or Midtown, with a caveat that those areas get developed. We already have extended the LRT out to the far reaches of the earth, we need to start making it more like a transit system, and not a commuter train.yeah I'd prefer if they focus on extending the blue line to the airport/more north and the red line more south before we add stops like Northland or Midtown
I still think they should connect the new denser suburbs in NE to the LRT line. Northbound Metis Trail and Deerfoot are a mess during peak times. Either way, I think we can all agree that an Airport line should be the number one priority if we had a choice.I’d rather see stations at at Northland or Midtown, with a caveat that those areas get developed. We already have extended the LRT out to the far reaches of the earth, we need to start making it more like a transit system, and not a commuter train.
The airport train would be nice though.
If I were to phase it, I would do:IMO all the transit $ should be going to the green line. Once that's under construction and the north leg is financed, we can look at filling out or extending the existing lines further. Looking at the map, the distance from Brentwood to Northland is about the same as the distance of the University to Brentwood, so not as close as they appeared. If adding a station is in the future, then this would be a good candidate, lots of room to add density too.
Don't forget extending the Redline down to Belmont. Lots of surburban density coming down there as well.If I were to phase it, I would do:
I think Green Line North probably is the best of those projects, however the first two are really low risk / high return in the immediate sense to really boost Green Line and Blue Line numbers.
- Blue Line NE to Redstone
- Green Line S to South Hospital
- Green Line N
But my list is thinking too small. Better yet, pick all three simultaneously and line up the project schedules to share resources, phasing, expertise and efficiency in delivery. Incrementally build out all of them at the same time so by 2030 we are done all of them and on to brand new projects.
