General rating for this project
  • Great
    Votes: 2 4.4%
  • Very Good
    Votes: 19 42.2%
  • Good
    Votes: 20 44.4%
  • So So
    Votes: 4 8.9%
  • Not Very Good
    Votes: 0 0.0%
  • Terrible
    Votes: 0 0.0%
So finally weather was a little less like a polar winter inside an arctic circle and more like just a cold winter day so I couldn't resist a little walk.
A little update from today:
The podium is not as good as I expected, but the tower portions are better. It's too bad they didn't pick a different material for the podium of the residential tower, or add more glass.
It's a brute, but once that fencing is down and there's the main level of full glass visible and you can see through into the building it should diminish the heaviness a minuscule amount.
I
The height of the parking floors in Guardian is about 15'. Not that that makes up all the difference. Combined with a possible slightly higher height per floor I could see it hitting the 127m. It's possible there was a mix up from IBI. Hard to say without seeing the latest DP. IMO the res tower looks taller in both the old rendering and the new one.
View attachment 94481 View attachment 94482
The retail floor and 3 levels of parking equate to 6-1/2 floors (going by a general measurement off the rendering) With a tower like Mark, the floors start counting right from the ground, and the main floor isn't terribly higher than normal. The bottom four floors of Mark are not much taller than 4 typical floors.
Whether or not it's 127m doesn't matter to me either, I just want the height to be accurate. True, it does seem a bit high, but when looking at the bottom 4 levels, and also the level between parking and first res floor, and the crown. It seems plausible.
It is a bit taller sense well I built it
I
Haha that's quite the first post bro. Welcome to the forum! And excellent shot.
Are you able to confirm the height of both towers? We've been going on 127 meters for the rental tower, and 117 meters for the hotel tower.
00-2016 Residence Inn topping out 003.jpg 00-2016 Residence Inn topping out 032.jpg 00-2016 Residence Inn topping out 046.jpg 00-2016 Residence Inn topping out 053.jpg 00-2016 Residence Inn topping out 117.jpg 00-2016 Residence Inn topping out 120.jpg 00-2016 Residence Inn topping out 169.jpg 00-2016 Residence Inn topping out 173.jpg 00-2016 Residence Inn topping out 187.jpg 00-2016 Residence Inn topping out 188.jpg 00-2016 Residence Inn topping out 191.jpg
00-1031_0000.jpg 00-1032_0000.jpg 00-1035_0000.jpg 00-1036_0000.jpg 00-1037_0000.jpg01-2016 Residence Inn topping out 138.jpg02-2016 Residence Inn topping out 149.jpg01-2016 Residence Inn topping out 121.jpg
