denfromoakvillemilton
If they want a station, it would have to be a cut-and-cover line, so that there would be savings to offset the costs of the added station.
The question I have is, what to do with the 2 West Highland Creek crossings (Trudelle Park and Pringdale Ravine) south of Lawrence. The southerly crossing looks quite shallow, and likely the line would have to go under. The more northerly (Pringdale) crossing seems to be a somewhat deeper valley and it may be possible to build a bridge with subway below - but I suspect that even here you may have to go under.
100% you are going under.
I used to drive along Danforth there to get to work.
The dip is quite small, there is no way the tracks would exceed the floodplain w/o being at grade w/homes on either side.
The real challenge for the line is the ravine crossing just north of Lawrence.
To cut under that, which is the assumption; based on where the water table sits, you have to be very deep, making the station, rather expensive.
Cutting above was ruled out, I'm not sure that its impossible, but it probably triggers lots of expropriation on the north side of the ravine as the train dives down again.
Was going above discussed in any official way?
I was thinking of raising the profile of McCowan by about 3.0 to 3.5 metres. Add to this the current bridge beams that are likely about 1.0m deep and you would keep the bridge soffit elevation roughly the same. With bridge girders of 4.5m deep, it could easily span twice the current bridge - so passing the Regional Storm should not be a problem.
No
Uh uh.
The current bridge sits very low over the creek.
You might be fine for regional storms; though w/increasing intensity, I don't think I'd want to bet on it.
The area below that bridge floods with some regularity. The ground is routinely saturated. Creekside erosion is a material issue.
The safe plan here would be, at minimum for the 100 year storm.
(which may soon be the 25-year storm, or less)
It wouldn't be impossible to situate the right height, but it would be expensive and challenging, unless you went over-grade. above Lawrence; but that comes with a different set of challenges, and likely no less expense.
They should cut and cover for sure. This should be done as quickly as possible.This image from a City of Toronto presentation is of the Birkdale Ravine, after the August 2005 storm.
Its just upstream from the McCowan bridge over the Bendale Branch of Highland Creek.
ICLR Friday Forum: Reducing flood risk in Toronto (February 2016)
ICLR held a Friday Forum workshop February 19, 2016 entitled 'Reducing flood risk in Toronto', led by David Kellershohn with Toronto Water. Urban flooding cont…www.slideshare.net
There is insufficient 'wiggle room' for a subway near the height of the existing bridge.
From a higher elevation, it may be do-able, but it would be destructive to greenspace, and costly.
I would only be surmising, but based on the low crossing of the East Don over Leslie, I think the TTC would look to build a fully sealed tunnel-bridge, rather than an open one.
I also imagine they considered it and ruled it out. Keep in mind the depth the tunnel would have to come from in the south, having gone under Highland Creek (different branches) twice before.
I'd suspect doubling the span of the bridge would help.
Maybe it's a similar argument to the Ontario Line crossing of the Lower Don.
If you are using TBM south of Highland, and also North to get into STC - then you would not even think about the idea of having the subway cross above this main branch of the river under the road. If you are using cut-and-cover both north and south, then it's a totally different story.
