sixrings
If etobicoke is serviced sufficiently by good access to the spadina line then aren't you also saying that scarborough would be sufficiently serviced with good access to a drl?
North York has a much better rapid transit service than Scarborough; two subway lines straight to downtown, with multiple stops. I live between those two lines and know first-hand how handy they are.
The fact that the city core generates lots of money and some of those are used to subsidize services in the suburbs, isn't in any way unique to Toronto. Many smaller towns and rural areas, too, are subsidized by revenues collected in big cities. That's the way the moderns financial systems work; it doesn't imply that downtown residents work more than suburbanites, or earn the right to look down at them.
This is the assumption from the post similarities combined with Coffey1 being banned and then OneCity account opening immediately after. I dont expect the person to ever admit they are the same person though.Coffey1 and OneCity are the same person?
For the 11 Billionth time, North York has the best service in the city, because its located in the centre of the City of Toronto and the GTHA. Any transit line connecting to the downtown core that travels north of Eglinton must travel through North York. It'll always have more subways than anywhere else in the city.
Actually North York is located mainly north of the centre of Toronto?
Using your logic of "Any transit line connecting to the downtown core that travels north of Eglinton must travel through North York. It'll always have more subways than anywhere else in the city". The same can be applied the any transit line connecting downtown that travel east of Yonge must travel through Scarborough
The geographic centre of Toronto is located in North York; Lawrence Park to be precise. North York is also a lot closer to Toronto's business and political centre than Scarborough. Surely it doesn't need to be explained to you why, in a radial network, locations closer to the centre will have greater service densities than locations on the periphery (such as Etobicoke and Scarborough).
Rapid transit lines in North York simultaneously serve Etobicoke and Scarborough (for downtown bound travel), due to the centrality of the borough. Rapid transit lines in Etobicoke or Scarborough only serve Etobicoke and Scarborough respectively.
Are you being intentionally obtuse? North York starts roughly north of Eglinton. Scarborough doesn't start anywhere near Yonge Street. You can't possibly build a rapid transit line running north from the downtown core that travels north of Eglinton without entering North York (at least not without an unnatural detour)
Your grasping at straws trying to justify the minor distance between downtown and NYCC and SCC and why pretty much all else is equal except transit should be drastically different. And surely you will have some imaginary central lines that justify VMC over SCC as well, or some reasoning why the Scarborough residents should be consequence connecting into North Yorks "justified" subway stub? The excuses not to properly connect Scarborough centre have costed us far more than if was done as per Scarborough's request pre streetcar/RT, and pre Miller LRT. And has left the door wide open for this type of Potlical scrutiny.
Both North York and Scarborough are similar in size, population, transit agency and City as to which it pays transit taxes into.
Coffey1 was banned for personal attacks on people pointing out his stupidity. As “OneCity”, he has toned down the personal attacks, but the stupidity is very much still there.
Now that your nonsense about Scarborough funding everything has been discredited, is this your new argument? Everything is nearly the same distance away??
NYCC is about 11km from Yonge and Bloor (in a straight line). STC is anywhere from 21-28km depending on the route taken. The one stop extension is 6km from Kennedy for crying out loud.
