UD2
Active Member
If you got flex hours I recommend leaving early. Leaving before 7:30 will save you almost 1 hour each day on the road (assume you leave work early too as in 4PM). Other than that I generally don't find the 401 to be too bad in the mornings. At least not when I was making my commute.
401 West -> 403 South -> Hurontario (if you turn right off the highway and do a U-turn back to avoid left turning queue)
if you leave at 730, and assuming there are no construction/accidents/weather/retards. your trip to Square One should take no more than 35 - 40 minutes. avoid the 401 collectors and use the express.
if you leave by 8. the same trip will take you 50+.
don't leave at 8:30
Coming back home will take longer. You should always budget over 1 hour for the way back.
I don't recommend DVP South -> Gardiner West -> etc
I don't recommand DVP South -> Gardiner West -> etc
and do keep in mind that this is assuming you proactively try to travel as fast as you, within reason and common attention to safety, can. if you're going to do 90km/h on the highway then you'll take longer.
don't leave at 8:30
