Glenco
I used to work outside as a surveyor. Knowing how quickly exposed flesh will freeze would have been helpful information not some fictitious numberHave you ever worked outside and especially up in height?
Well they're saying 5 mins right now so I'd say it's not safe to be working outside, regardless of whatever rant your on about windchill.I used to work outside as a surveyor. Knowing how quickly exposed flesh will freeze would have been helpful information not some fictitious number
Exactly, that is what is most relevant, not different temperature numbers that are just confusing.I used to work outside as a surveyor. Knowing how quickly exposed flesh will freeze would have been helpful information not some fictitious number
Someone just told me it was -50 here several years ago. No, actually it was not. It hasn't been -40 or over in Edmonton since 1972.
Not true. This is why wind chill factors should not be used they just lead to confusion.It's been well into the -40s (maybe with WC) in the last decade and I think recall a -51 'coldest place in the world' or something.
My memory of that coldest place in the world thing is -46 lol. But there has definitely been -40s many times since 1972…It's been well into the -40s (maybe with WC) in the last decade and I think recall a -51 'coldest place in the world' or something.
So you would agree that a calming -31 is a lot tolerable than -31 with wind? It is not the mercury that change but wind with the mercury will make it colder.I used to work outside as a surveyor. Knowing how quickly exposed flesh will freeze would have been helpful information not some fictitious number
Posted my reply on For What It’s Worth.So you would agree that a calming -31 is a lot tolerable than -31 with wind? It is not the mercury that change but wind with the mercury will make it colder.
You stated fictitious numbers which they're are not hence why it always stated "fells like".
Now, if you work outside but working up high without coverages, that dynamic turns outrageously like perdition as the vortexes changes in elevations.
This is why, generally, they give people the options to work once it passes -28 (without windchill). At -31, they automatically shut it down.
There is only one north tower -- that accompanied with a low-rise retail building (I believe that encompasses Phases 1 and 2). Phases 3 and 4 are the two south towers.
pretty sure its just one tower and the shorter commercial buildingView attachment 535156
Does this snippet indicate that 2 towers are indeed what is under construction at the moment?
But “495 units” as per the press release in 1 - 20 storey building?pretty sure its just one tower and the shorter commercial building
