The Valley West will make it desirable to ditch a car for the first time in Edmonton. Being able to reach every attraction in the city will be a big thing.
If you're Downtown. But Downtown already has a frequent express bus that will likely get you to that main west end attraction much faster than the LRT will.
Not just if you're downtown. Pretty much anywhere within the LRT network will be connected, which is a much more streamlined and reliable way to do it than with buses.
Also, unlikely that the bus route will be faster than the LRT. Currently, if you use the express route it takes about 35 min (and for that you'd have to take it in one of the few stops along the way, which can add substantial walking distance/time to the trip), and about 1hr if you use the regular lines. I doubt the LRT will take more than 45min from 102st to WEM.
If you're downtown, you will have easy access to, well, all corners of the city, basically. If you live in Mill Woods, you're not taking the LRT to get to Southgate or the UofA, even if those technically are connected by LRT. I fail to see what is unique to Valley Line West that will "finally" make ditching the car feasible in Edmonton in a way that Valley Line SE, the Capital Line, or Metro Line haven't done. It'll be a boon for those on/near the line, or Downtown, and will likely be used if you're going from, say, Stadium to WEM, but probably not if you're going from Century Park to WEM. For people in the suburbs, even if there's an LRT line nearby, the likelihood it'll actually connect you to all of your daily needs is lower unless you live Downtown and you have tremendous LRT access. Once the Metro Line goes to Castle Downs, you still won't be able to get to where most in the area go for shopping, Skyview, by LRT, because of foolish routing choices.
Regarding travel times, the 900X was faster before the LRT construction. Valley Line SE does not promise a faster ride than the bus from DT to Mill Woods and although I haven't seen anything similar for the west line, because it is being built similarly, I wouldn't be surprised if it's about the same speed, just higher capacity and grade-separated. These low floor trams are not the highly efficient trains we're used to on the Capital Line. The Valley Line, as slick as it looks, feels like it's going to be less efficient once it finally opens. More stopping, higher likelihood of car crashes, lacking true signal priority, and at-grade through downtown (we will regret this I'm sure... look at Calgary).
The point I'm making is that it's now a simple choice to live in a more central location than to live in a newer suburb and be forced to own a car. My suggestion would be to live along the valley west line between Oliver and Jasper place, or the South line between Quarters and Bonnie Doon.
I'm choosing to move centrally for a better quality of life day to day.
I also don't really care for busses, so I'm not really interested in the ride times. I'll stick to the trains, and so will many others.
It has been established that all things equal, trains attract more riders than busses for the simple reason that people prefer trains, as you noted.
The line will be a very nice addition to the city.
We should aim for a complete, multimodal system, both a great tram like network for urban interface and a robust subway like network for mass capacity, commuting and speed as the city grows. We can and now will have both and should expand both.
The central locations are generally more expensive, even though there are deals to be had in some locations. Any family starting out will probably live in the suburbs or even bedroom communities.
It's cheaper for many to live in central Edmonton when you factor in vehicle costs. Having grown up in both Grovenor, and later Ormsby, I can tell you that it was the same amount of money for a worse quality of life.
More large apartments and townhomes are definitely needed in the central areas for families.
100%
How have areas like Westmount and Grovenor not seen any real movement in regards to multifam projects? Westmount especially. I lived there for awhile and loved it, but didn't love my 60s built lowrise building, but of course there's extremely few apartments built within the last 30 years anywhere in the whole neighbourhood.
100%
They are getting there. The south end of Grovenor is getting alot of infill. I expect Valley West to speed up development in the SW and SE corners. East Westmount is getting very expensive, due to its proximity to 124th shops the Valley Line should help encourage multifamily across the street from where Western Cycle used to live.
The best value in the city for both proximity to DT and access to the LRT is probably Parkdale. A young family can get a brand new duplex for $300k-$330k.
What this article failed to mention is that Brandon Schatz is the owner of Variant Edition Comics who moved his store to Stony Plain Road just a couple of years ago when he fully knew that the LRT construction was forthcoming and would disrupt his business.
