I know people won't like this comment but if this is an upgrade over the bus capacity, comfort and reliability but not much faster than the bus I am going to be happy. This has been one of the fastest projects from start to finish to build once money was committed. A lot of Toronto streets could use such improvements yesterday. (Lawrence) (wilson/yorkmills/ellesmere)
Maybe, but does the benefits match the cost?I know people won't like this comment but if this is an upgrade over the bus capacity, comfort and reliability but not much faster than the bus I am going to be happy. This has been one of the fastest projects from start to finish to build once money was committed. A lot of Toronto streets could use such improvements yesterday. (Lawrence) (wilson/yorkmills/ellesmere)
Finch was mainly built to increase capacity, so this isn't entirely a controversial opinion. They probably should get rid of the stops with no bus connections, but other than that, the way they're building it is, for the most part, fine, even if it's being built as a streetcar with fewer stops.I know people won't like this comment but if this is an upgrade over the bus capacity, comfort and reliability but not much faster than the bus I am going to be happy. This has been one of the fastest projects from start to finish to build once money was committed. A lot of Toronto streets could use such improvements yesterday. (Lawrence) (wilson/yorkmills/ellesmere)
A lot of people who live in said neighbourhoods also work in and around the airport, not only that but if it did get extended to the airport, there will be a lot of connections at the new transit hub.The raison d'être for Finch West is kind of why I don't think it's a good idea to extend it to Pearson. The future GO station at Woodbine, yes, but not Pearson. There simply won't be the demand for people to use an on-street LRT that passes through Rexdale, Mount Olive, Jane and Finch etc. when they can get faster transportation out of the airport area on the UPX, Eglinton West, or a future unplanned rail line.
That being said, the extension south to the future GO station should start to be drawn up not long after the line opens, preferably with Woodbine Entertainment funding a portion of the studies.
Lawrence and York Mills could be two good streets for BRT-lite style transit lines. A Lawrence-Dixon line could potentially connect the airport, the Weston GO station, and the two YU subway lines together, IMO.
The only problem with Lawrence is that it's separated from its Eastern section by the Bridle Path. There's no good way around it, putting transit through it will be politically impossible, and a tunnel is expensive.
