ARG1
It hopefully never shows its ugly face again.The Sheppard East LRT was lime green, but later changed to teal (but who knows what’s happening with that) at the same time.
Battery technology? The LRVs will be battery operated?
The use of pantographs on the TTC streetcar system massively reduces the need for near perfect radii overhead cables and lots of supporting cables. You'll see this change (sloooooowly) in Toronto over the next few years. Obviously Finch + Eglinton will be built to modern standards from the start, so you won't see cobwebs of cables over intersections to the same extent.It would be nice if the streetcar lines could lighten up on the overhead wires. Maybe just for intersections/turns where it gets very messy.
Small on-board batteries/supercapacitors could achieve the same thing.The use of pantographs on the TTC streetcar system massively reduces the need for near perfect radii overhead cables and lots of supporting cables. You'll see this change (sloooooowly) in Toronto over the next few years. Obviously Finch + Eglinton will be built to modern standards from the start, so you won't see cobwebs of cables over intersections to the same extent.
On Eglinton/Finch, one won't even see the complexity like the streetcar intersections. The most complex areas would be the T-junction to the yard and the crossover area.The use of pantographs on the TTC streetcar system massively reduces the need for near perfect radii overhead cables and lots of supporting cables. You'll see this change (sloooooowly) in Toronto over the next few years. Obviously Finch + Eglinton will be built to modern standards from the start, so you won't see cobwebs of cables over intersections to the same extent.
If Doug Ford was smart, for the next election he would fast track the Finch West LRT East Extension, along with the Sheppard Subway extension.
I'd much rather see Line 4 extended to the west than a Line 6 extension to the east in terms of priority but I agree with you for the most part.If Doug Ford was smart, for the next election he would fast track the Finch West LRT East Extension, along with the Sheppard Subway extension.
Should Finch East be at grade or underground?If Doug Ford was smart, for the next election he would fast track the Finch West LRT East Extension, along with the Sheppard Subway extension.
I want both but I'd say do the west extension to the GO train first as it's both cheaper and much simpler.I'd much rather see Line 4 extended to the west than a Line 6 extension to the east in terms of priority but I agree with you for the most part.
Mostly at grade I'd think, except perhaps near Yonge - and perhaps Don Mills. Though elevated is surely an option too, and would be much quicker to build than going underground ... but I'd like to see underground at Yonge.Should Finch East be at grade or underground?
Wouldn't be able to do much more than announce it. I don't think the planning for Sheppard is all that advanced.If Doug Ford was smart, for the next election he would fast track the Finch West LRT East Extension, along with the Sheppard Subway extension.
