Speaking of Mississauga BRT, that service and route is perfect candidate for an LRT service. You have proper stations, You have good spacing of stops (one km plus for each stop), you have complete grade separation, its a road that is used only by City buses, and you have the right density for an LRT. LRT's do have place and that's perfect place to put a proper LRT. Just not in Toronto.
PS.: I recall hearing that there is already been talk of doing just that with that route and that it was built with future LRT service in mind.
When you say Mississauga BRT, are you referring to the Transitway?
Why upgrade a bus Transitway to an LRT? Why repeat the mistake that Ottawa made?
Why not upgrade it to something like the Merseyrail in Liverpool? Or the Tyne & Wear Metro in Newcastle? A light Metro. Have it go underground when it passes through the Square One area. Heck, if we were smart, we would even have the Hurontario line use the same rolling stock and offer seamless transfers. Travel on elevated lines south to Port Credit, and go underground in downtown Brampton.
Exactly.
The bus works better than an Ontario-designed/operated LRT ever would.
Limit on the transitway right now is 80, I'd expect that to go down if an LRT was routed there for "safety."
The transitway could be amazing if MiWay stopped padding its schedules so much.
Snow on switches caused it to be shut down as well as communication issues.
Maybe it would be a good idea to have crews actually proactively clean the switches. It's not like they didn't know it was going to snow.
Seems like a no brainer
Snow clearing should be Mosaic’s responsibility. And it appears both times we’ve had snow, they’ve done a shit job.
There is another major downside in this service is the sheltering at the station stops. I rode a portion of the line Wednesday (just to see it for myself) and on the return trip i had to wait at one of those stops for about 5 mins and i kept wishing that the stops would protect me from the weather as well bus stop shelters. You get much better sheltering from the elements at a bus stop than at the Finch LRT stops. The typical bus stops, though smallish, protect you well from the wind and precipitation when you go deep inside it. Whereas these stop shelters on this line barely protect you from precipitation and leave you fully exposed to wind and cold. ;
Ironically, I remember someone at Metrolinx once stating that more weather cover wasn't particularly necessary due to the frequency and reliability of what they were building. In other words, nobody would be waiting more than a few minutes.
The Simpsons Monorail song really incapsulates everything doesn’t it…..
“An LRT will do the job! Just ignore the detours and cost overruns! ELL ARE TEE….ELL ARE TEEEEE…..ELL ARE TEEEEEEEEEEE”
“Mono….doh!”
“Mono….doh!”
Respectfully... Shut Up. This is a new line experiencing all the new line issues. Issues that will be worked out the longer it operates in revenue service. Your continuous beating of the dead horse is not going to change anything.
Three obvious stops to remove are
1. Driftwood
2. Duncanwoods
3. Stevenson
These stops don't need to be removed to improve service. All you would accomplish by doing so is removing service from areas that are currently in the works for redevelopment and intensification.
@jordanmkasla2009 They're ragebaiting anyone who still has some sympathy for trams in Toronto. Out of the 4 current LRT projects, the only real defence IMO should be for the Hamilton LRT at this point, even if its 2023 routing change is highly suspect. The Hamilton LRT's route has significantly more density with more significant trip generators in McMaster University, Downtown, MacNab Terminal, and Eastgate Mall. And its future demand growth (related to its proximity to Toronto) is right at a point where a metro wouldn't be needed, or at least wouldn't be needed for a very long time.
Hurontario cuts through the largest CBD outside of Toronto proper, and is poised to be the busiest corridor in Mississauga (aka future West Etobicoke/West Toronto;)). Eglinton similar story.
Finch West is not dense enough for a tram, and unfortunately it doesn't look like it will be dense enough any time soon. Consider the fact that Toronto proper has about 200 tower cranes versus 2nd place Los Angeles with around 50. Toronto is the fastest densifying city in North America in terms of mid/high-rises, and yet there are hardly 3 apartments/condos in pre-construction along Finch West right now, 11, 12, and 30 storeys west to east. Developers have had ample time since Line 6 started early construction in 2016 to build in anticipation of a modal upgrade to tram:
"*Starting Q3 2024, Toronto will report on an altered survey area. We will be implementing a revised radius for crane counting, prioritizing the downtown core area, which has the highest density of construction projects. The revised radius is 3.5km from the Bloor St W and Avenue Rd center. As of Q1 2024, this core area contributes to approximately 35% of the overall Toronto crane count (80 cranes)." Rider Levett Bucknall
I concur with @FW36's post which is why I always say in hindsight Finch West definitively did not deserve a tram. IMO, without hindsight, it would've been only erroneous to upgrade Finch West before/without doing bus lanes throughout the city, especially Old Toronto.
To be fair the set of facts before 2020 leaned towards building the LRT
1. The 36 bus ridership was steadily increasing and a lot of buses were running at capacity. I remember during rush hour sometimes multiple buses would pass-by without stopping due to capacity issues or up to 5 buses would be bunched together and all completely full.
2. Around 2010's Humber College announced they would focus there expansion project mostly on there north campus. York University also had expansion plans so it was safe to assume further increase in ridership from the greater amount of students
3. Interest rates before 2020 were low. The city wanted to encourage more private development for housing as there was a lack of new residential construction along the corridor. Historically LRT encourage more development than BRT. This would have resulted in more housing options for those who live around the area
So overall prior to 2020 the big picture was buses already having capacity issues, expected growth of post secondary education in the area, and potential for large scale redevelopment and population growth leading to even higher ridership.
Now let's look at the current set of facts.
1. Ridership for the 36 bus has decreased since the pandemic and has not recovered.
2. Currently there is a decrease in the enrollment of international students and increase in the amount of classes offered online. Humber College North has slowed down its plans as well
3. Interest rates are higher than before plus increase on development charges are making it is harder for developers to build. Most likely a lot of residential projects along the line will be delayed or canceled.
With current set of facts a BRT would be more justified, it would have been cheaper the build and provide required capacity.
However a lot of the draw backs were because the pandemic. If it never occured mostly likely the 36 would have continued to see increased ridership, I imagine online classes would not be as common, and if interest rates remained low I imagine there would have been more opportunities for redevelopment projects.
I don't think planners were thinking what impact a potential world shaking event would have on the Finch West LRT back in 2010.
As the line currently stands a BRT would be acceptable. But an LRT can still be also justifiable, it would just require the city to do more work. Giving the LRT priority, increasing speed limits, and better stop placement would mean faster transit encouraging more ridership. The city could lower development charges and change zoning laws to encourage redevelopment along the corridor. The city could also lower develpment fees for post-secondary institutions to encourage investment. With these changes I would say LRT is perfectly fine and acceptable, but if Toronto tries nothing to improve the current situation than it 100 percent Finch west should have been built as a BRT
The Line 6 Finch West corridor is as dense as the iON LRT corridor and many said it didn't need an LRT either, yet the iON LRT is the most used transit route in KW now and is spurring further development along the corridor and the Region there is moving forward with it's stage 2 expansion down to Cambridge.
Love that the back up service (buses) was faster than the service it was saving them from. Haha. "Don't worry folks, we hope to have the slower service repaired soon."
When it comes to adding ridership the BRT is probably the most useless transit decision in our province. I think I've seen at most 5 cars? In any of the parking lots.
For bypassing traffic it's great but that's about it IMO
1. Currently zero proposals for redevelopment near Stevenson. I understand albion mall could be redeveloped, but any condo built On Albion Mall property would still be at most 300 meters away or closer from either Stop at Kipling or Albion. That translate to a 4 minute walk or less to get to a stop. That is not a lot.
2. Currently zero proposal near Duncanwood station. The only two residential proposals are closer to Pearldale and Milvan. If there is a development proposed near Dancunwoods in the future luckily it would only be 5 minute walk to either Pearldale and Milvan.
3.Now for Driftwood station I understand Jane and Finch mall is being redeveloped along with surrounding area. From any point of all the proposal for new condos it would be 300 meters or less to Jane and finch station. Again that translates to a 4 minute walk or less to get to a stop from any new development.
I'm not saying remove station that would lead to additional 10 minute or longer walk, that would be to long. The amount of people who think a 5 minute walk or less is to much concerns me. For people with disabilities there is wheeltrans, or TTC could offer a local bus service. For those who are able and willing I recommend going on 5 minute walk get fresh air. 5 minutes is not long.
I agree with you about stops though I wanted to interject and mention wheeltrans is useless for anything you can’t schedule a day in advance!
To add, the Jane and Finch Mall, which can nowhere near be considered a huge mall, stretches from the Jane and Finch stop to the Driftwood stop. If you wanted to go to the Tim Horton's, you would get off at the Jane & Finch stop. If you wanted to go the McDonald's at the other end of the Mall, you would get off at Driftwood. That's how close these stops are.
