"Middle of a light industrial wasteland" can describe many GO stations, not just Etobicoke North. Bronte, Appleby, Oshawa, Bramalea, Meadowvale, Ajax...
It's because the MTO owned (and still owns) some land in the area when the station opened in the mid 1970s. That, plus the hydro corridor passing overhead made getting the land for parking easy. It was a cheap station to build, and it attracted just enough commuters to make sense.
I used that station a lot back in the day. I’d drop off my family at work and then take the train downtown. There was also a powerlifting gym not too far from there.
Its also close to the 401, its a good station to park at and take the train the rest of the way downtown to avoid traffic if you are driving along the 401.
Construction at Milliken Go Station is progressing, with majority of the work focused on utility/watermain work underneath the future roadway. Progress is also being made on covering and reinforcing the pedestrian tunnels under the tracks, so that they can start building up the second platform, which has already started in some areas. The first piece of black cladding had went up, and the work between Redlea Ave and Kennedy Road is progressing well with new curbs, new medians, new bikelanes, and new asphalt already in place, almost ready to move onto the north side of Steeles Ave.
I wonder if this is level boarding at the NA industry standard (32 inches?) or GOs own level standard. I hope it’s the former so VIA can easier use these stations.
All the documentation says their standard is currently 5 inches and they are moving to 24 inches. If they were going to move towards a standard you would expect they should aim for 550mm or 21.6" (most common European standard) or 1250mm or 49.2" (a high-floor platform standard that would accomodate the 50-51" train floor heights common in North America and the 1250mm floor heights found in many HSR trains).
Interesting that in China they have the platform standard heights of 200mm (ultra low), 380mm (low), 550mm (medium), 760mm (high), and 1250mm (ultra high) nicely aligned to the most common global standards, but we are using 5in (127mm) and thinking of going to 24in (610mm) and VIA has 3 stations at 48in (1219mm). Oh well, at least our track gauge for new things is 1435mm (standard).
It will likely be low floor level boarding, so not in line with Via
Apparently, all new GO stations will be built with level boarding in mind and an IBC is being prepared currently. Dated August of 2020. Page 32. https://www.metrolinxengage.com/sites/default/files/appendix_m5_-_pic_2_summary_report_part_8.pdf
although interesting this isnt anything new, in fact i think this is copy paste from 3 years ago in 2018
the technical report can be found here from 2018 on pg 8http://www.metrolinx.com/en/regionalplanning/newstations/2018-04-13%20Stations%20Technical%20BackgrounderFINAL.pdf
Metrolinx is currently preparing an Initial Business Case (IBC) for level boarding across the GO rail network. Level boarding will provide significant accessibility benefits for customers while also reducing station run-in and dwelltimes. The total run-in and dwell time at stations built for level boarding is expected to be reduced by approximately 30 seconds per station.
compared to the coment response last fall
That said, not building stations in progress with level boarding sucks. they might be talking about new stations that have planning started in the future
