Bordercollie
Could they have different wayside power units for VIA and GO? Different colours?
Sure, but.....Could they have different wayside power units for VIA and GO? Different colours?
Someone mentioned that there is a rumor that they want to get service started in October so if that's true, then they should get started on that now....Sure, but.....
You still need them to output different voltages - VIA uses 480vAC and GO uses 575vAC. That's not an overnight thing to fix - it will take several weeks at least to set up the new feeds to the distribution network, install new transformers, install the new wayside cabinets, run conduit, etc.
| Westbound (down) | Westbound (down) | Eastbound (up) | Eastbound (up) | |
| Toronto | 06:30 | 17:19 | 09:43 | 20:29 |
| Kitchener | 08:08 | 19:05 | 08:02 | 18:51 |
| London | 09:59 | 20:56 | 06:11 | 17:00 |
Heading to ONR shop?
Probably. It's within a klic or so of being there.Heading to ONR shop?
Hopefully the schedule is both ways at both rush hours (although at the speed of this corridor using the word "rush hour" is a misnomer).
Westbound (down) Westbound (down) Eastbound (up) Eastbound (up) Toronto 06:30 17:19 09:43 20:29 Kitchener 08:08 19:05 08:02 18:51 London 09:59 20:56 06:11 17:00
I don't really get what the point of them is? Hasn't always been said that having seat belts on a bus could make it harder for someone to get out in the event of an emergency?
So is this because of rules on motor coaches or the seats on the bus? The enviro isn't technically a motorcoach by pure definition is it? Anyone know the exact text of the regulation?It does in a way as it takes time to remove the belts.
The reality is though that if a bus slams on the brakes passengers will go flying. That is likely why they did this.
