steveintoronto
Superstar
And the two spurs of the Fergus Sub which connect right there?Underpasses and road closures would be an even better solution!
Agreed. HFR, yes, unless a by-pass is built around much of the north mainline. Well at least the HSR concept keeps Collenette employed.I don't think we will ever see trains blasting thru Guelph at such a high speed as to make switches a problem.
Source: http://www.guelphmercury.com/news-s...-discussion-of-guelph-s-high-speed-rail-stop/[...] During the discussion, which included the province’s special advisor for high speed rail, David Collenette, Guelph Mayor Cam Guthrie, city staff, the University of Guelph and the Guelph Chamber of Commerce, it was indicated that the rail line would bypass Guelph.
But according to a city hall report, more recent discussions suggest that an alternative alignment through Guelph may be considered, depending in part on city support.
In spite of Allt’s objections, council showed its support, with all members voting in favour of the recommendation. [...]
Nothing is set in stone, but the default argument is that the bypass is a given (For HSR) unless Guelph can make it otherwise. Guelph is unlikely to do so, claims *by some* to wanting to do so to the contrary. Guelph is looking to the Feds to bring the present rail-line level crossing status up to Transport Canada directives. Silvercreek crossing was closed by Transport Canada some years back and the 'go slow' order placed on the rest of the west end of the city stretch at the same time.The bypass does not seem to be set in stone, as per the newspaper article quoted below:
http://www.guelphmercury.com/news-s...-discussion-of-guelph-s-high-speed-rail-stop/During the discussion, which included the province’s special advisor for high speed rail, David Collenette, Guelph Mayor Cam Guthrie, city staff, the University of Guelph and the Guelph Chamber of Commerce, it was indicated that the rail line would bypass Guelph.
Given Metrolinx is wanting to deploy CBTC for RER...The only good thing I can say about the CTC is, it's such a bare bones installation that we won't piss away all that much money when RER rips it out for whatever comes next. (I wonder how much CTC remodelling the Barrie and Unionville doubletrack projects are causing....the CTC there is almost brand new also)
Yeah, I was thinking much along the same lines, that is forward compatible. There are some lines in Europe (and off-hand, some in the US too, albeit that may be APTA but not FRA compliant) where there are *no* external signals. Mind you, if it it's driverless, then visual signals are a bit moot anyway...Given Metrolinx is wanting to deploy CBTC for RER...
Traditional block signalling (if fully maintained in in spec) can in theory be a fair fallback for CBTC failures. CBTC fails can simply cause trains to automatically brake, and can resume using block signalling as a fallback.
There will probably be a very long phase of block signalling (which may be CTC controllable) that operates concurrently with CBTC, and new operating rules permitting multiple trains into occupied traditional blocks in a fully-CBTC-compliant corridor, when both block and CBTC rules are simultaneously working properly, and only if every single train in the CBTC-controlled corridor all have required CBTC.
Transport Canada new rules for CBTC corridors may deviate from this, but it might in theory go somewhere apporoximately along these lines.
So they don't need to rip these out for RER during a CBTC-overlay situation.
Indeed, CBTC can be made the sole signalling system.Yeah, I was thinking much along the same lines, that is forward compatible. There are some lines in Europe (and off-hand, some in the US too, albeit that may be APTA but not FRA compliant) where there are *no* external signals. Mind you, if it it's driverless, then visual signals are a bit moot anyway...
LOL! Hey, if the Tories get back in, watch out for the Slasher!But I would be fully shocked if Metrolinx did a cold-turkey transitionless changeover.
