CapitalSeven
I still dream there is a secret HFR RER HSR Missing Link table going on behind the scenes. Report will be under my tree in just 5 days.
This proposed HSR will do nothing for anyone in suburban Toronto though....so there is that.I think you will now see a Lon/KW/Pearson/Toronto HSR line going ahead probably under construction within 5 years.
It's not like the Tories would ideologically be behind it but to not build it would come at a very heavy political cost. Suburban Toronto and London & KWC are key battle ground areas that the Tories will need if they want to form government. All three areas have a record of vacillating between the Liberals and the Tories with London being slightly more centre-left and KW more centre-right. The next election won't be fought in the small town or downtown Toronto but in these areas. The NDP at this point are starting to {like their federal counterparts} look irrelevant and it's hard to say where the hell they will end up on the issue.
That said, there are spinoffs -- Electrified GO, electrified VIA -- many of which will run on the same HSR ROW -- and the Freight Bypass is important to all the above.This proposed HSR will do nothing for anyone in suburban Toronto though....so there is that.
I think the billion dollar question is about what the PCs will do in power. Are they even aware of the HrSR (it's not HSR) and how it meshes into the RER plan? I doubt it.
I am betting that they cut GO RER. And push the previous Hudak plan. And to make up for all that, they'll expedite a few LRT/BRT plans in places like Hamilton and London.
Has anyone ever explained how a HrSR (not sure what that means but don't want to get into a discussion about terminology so I'll adopt yours ) meshes with RER? The proposal on the table is a train that serves London-KW-Pearson-Union......yes it uses the same corridor as a proposed RER line....but the only station they have in common is Union....not sure how that is "meshing" with RER.I think the billion dollar question is about what the PCs will do in power. Are they even aware of the HrSR (it's not HSR) and how it meshes into the RER plan? I doubt it.
Eglinton should be the one line Hudak does screw around with. It should be a full Metro from Kennedy to Renforth and not LRT and it is not to late to do precisely that. The LRT as opposed to a grade separated system more costly to run, has the least capacity, the slowest, the most unreliable, has the biggest impact on the current road itself, and has the worst frequency potential.
But yeah, regardless of party, extending the 12 lanes of 401 is a lot more profile out there than any flavour of intercity rail expansion.....
I would go with the FRA regulations quoted in the Wikipedia article:
Wikipedia said:Another limitation is the safety of grade crossings which limits how fast the trains can go. FRA regulations set speed limits for tracks with grade crossings as follows:[33]
- For 110 mph (180 km/h) or less: Grade crossings are permitted. States and railroads cooperate to determine the needed warning devices, including passive crossbucks, flashing lights, two quadrant gates (close only 'entering' lanes of road), long gate arms, median barriers, and various combinations. Lights and/or gates are activated by circuits wired to the track (track circuits).
- For 110 to 125 mph (180 to 200 km/h): The FRA permits crossings only if an "impenetrable barrier" blocks highway traffic when a train approaches.
- Above 125 mph (200 km/h): No crossings will be permitted.
