Chinese_T
Active Member
New infill proposal in Mount Royal
15 Units on a site only 18 meters wide!
Really creative land use, but I don't envy those people living in the middle units with almost no sunlight...New infill proposal in Mount Royal
Location premium is the play here, not sunlight. The area is full of apartment buildings from previous decades that also made that trade-off - half of all units in the neighbourhood are north facing and get less sunlight that even those townhomes.Really creative land use, but I don't envy those people living in the middle units with almost no sunlight...
Might be available here https://secondarysuites.calgary.ca/ if garden suites (by your wording, I am guessing you mean Backyard Suite in City of Calgary parlance) that may or may not be in the same structure as a carport or garage, not ground level apartments) are included in this definition. Sourced from this database, which has ~11,700 registered secondary suites in it. https://data.calgary.ca/Business-and-Economic-Activity/Secondary-Suites/jwn6-r58yHi: I am wondering where the most up-to-date information is on statistics for garden suites in Calgary might be found? I am also wondering if the zoning has been changed to allow for more than 2 units per lot. Change is coming! Thanks!
153.1 "Backyard Suite"
24P2014, 15P2016
a means a use that:
i contains two or more rooms used or designed to be used as a residence by one or more persons;
ii that contains a kitchen, living, sleeping and sanitary facilities;
iii is located in a detached building located behind the front façade of the main residential building;
iv may be attached to an Accessory Residential Building;
v is considered part of and secondary to a Dwelling Unit;
vi except as otherwise indicated in subsection (vii) and (viii), must be located on the same parcel as a Contextual Single Detached Dwelling or a Single Detached Dwelling;
vii in the R-CG District or a multi-residential district must be located on the same parcel or bare land unit with a single Dwelling Unit; and
4P2017, 62P2018, 56P2022
viii in the R-G and R-Gm Districts must be located on the same parcel as a Dwelling Unit in a Rowhouse Building, Semi-Detached Dwelling or a Single Detached Dwelling;
b is a use within the Residential Group in Schedule A to this Bylaw;
c requires a minimum of 1.0 motor vehicle parking stalls; and
d does not require bicycle parking stalls — class 1 or class 2.
Agreed that location is the premium here. But are there many buildings that face the wall of another building? North facing apartment may not have direct sunlight but there should be decent natural light. These interior units on the lower floors would face the side wall of the building next door. The higher elevation unit to the south will block most of the light from that side as well.Location premium is the play here, not sunlight. The area is full of apartment buildings from previous decades that also made that trade-off - half of all units in the neighbourhood are north facing and get less sunlight that even those townhomes.
Plus, there's only so much you can do in this specific location - I lived down the street from here for a while and was very surprised how much the actual Mount Royal hill reduced sunlight in the winter. Made for icy sidewalks!
Seems like a good fit on a narrow lot with very steep topography.
And these will be modern apartments, likely with modern amenities. The area doesn't actually have a lot of that - plenty of shared laundry, limited amenities due to the 1950s, 60s and 70s era vintage apartments making up a large portion of the stock.The market will dictate rent or purchase price for those units with lack of sunlight/daylight being a factor. It's up to the renter/purchaser to determine whether it's critical to them or not. However right now, lack of inventory is a more impactful factor so as long as they're not priced on an extreme end they'll have no trouble being occupied.
Isn't this just a product of development economics of the current climate?It is another example though of the density not living up to what the LAP called for. 4th Street is planned to be a Neigbourhood Corridor, lined with 6 storey multi-family apartments with retail at grade for some of it. But, due to the nature of H-GO, we aren't seeing that, instead getting 3-4 projects of this scale, rather than the bigger density that the policy document called for.
I've said this before but 4th st could be converted to single lane traffic all the way from 16th ave to McKnight adding on-street parking and a separated bike lane. Would make fronting onto it a lot more appealing.I pass by that infill site all the time. My only wish is that entrances faced onto 4th street instead of being a building side. This seems to be the common articulation for many developments along 4th street, which is unfortunate as 4th street has potential to be a nice little corridor. Still the density boost is great for the area.
