No one is trying to build infill townhouses in deer run... rezoning didn't change where townhouses were being built it just makes it easier and less expensive.
If no one is trying to build rowhouses in Deer Run, then no one should have a problem with reverting to pre-May 2024 zoning laws.
Except reverting to pre-may 2024 zoning laws would needlessly add time and therefore cost to the development of townhouses. Could rezoning have been applied to targeted neighbourhoods where it is already happening? Sure, but then that would open a giant can of worms over which neighbourhoods deserve to get beaten with the rezoning stick. Better to just rezone the whole city than have that ridiculous debate.
Reverting isn't the end of the world, it's just a big missed opportunity to be very proactive for the future for once. 30 years from now SFH owners aren't going to be any more eager for their neighbours to lose exclusionary zoning, and at that point there will be a higher probability for imminent change.
The issue obviously isn't Deer Run. It's Glendale (for instance). LRT station is at 'h12' at the top centre of the map. It's less than 500m down to the reserve running E-W through the middle.
2023 maps:
Today:
There was some mention in the council meeting that H-GO wasn't necessarily reverting, but I don't see why that would be the case based on the notice of motion. In any case, this map shows a ton of opportunity being put on the wrong side of bureaucratic hoops. And there are dozens of other maps just like this.
Councillors have suggested they will use LAPs (which don't exist yet in many/most areas) to bring back targeted rezoning. I think this will be way slower and more arduous than they expect.
Last thing I'll say is that I think the 'Missing Middle' of housing is an issue that is more pronounced in Vancouver and Toronto as both cities have more developed Transit nodes and more historical single family housing that residents are willing to protect. I also think that the Federal Housing Accelerator Fund was geared towards both those cities than it was towards Calgary or Edmonton.
I'm not saying that Calgary doesn't have a missing middle, but there's so much vacant and underutilized land within the downtown core, the inner city and around C-train stations that should be prioritized in development.
I'm of the mind that we can do both. We can encourage investment in places that already have great amenities and infrastructure, though usually this is risky because these projects will be huge and you can't really project when or if they will happen - and we can also improve places that aren't there yet incrementally, with lots of little projects that are safer, and eventually create a reason for the City to improve transit and infrastructure.
It's a win/win, but if you're of the mind that we should only do one of the two, you should at least let Council know that — Cllr. Ward very angrily voted down an amendment to keep R-CG in areas that are 600m from transit or closer; he said it's "just blanket rezoning under a different name," - Cllr. Dhaliwal (usually supportive of housing) called it "mini-blankets."
The way this Council is headed, we're going to get infill nowhere.
2023 maps:
Today:
Frankly, R-CG isn't nearly dense enough a base zone for areas like this.
Prepare to be disappointed by the LAP:
The above is 'Building Scale'. The 'Urban Form' map below seem to get more attention and more frequently referenced in land-use hearings (and it's just easier on the eyes overall), but there are a number of areas scaled lower in building scale than below (though tbf portions of 37th are scaled up for building height).
Of course the maps are just about slightly different things, but they'll both inform the final rezoning. I expect each LAP to be fully re-litigated when it's time to implement the associated land-use maps. And this council has already demonstrated that they'll overrule a brand new LAP when they rejected an 'up to 6 storeys' proposal that was totally in compliance.
Pretty much every city in Canada needs a bump in infill development. If we do that now RCG will likely fulfill our needs despite never really touching communities like Deer Run. If we hold off and revert back to R1 zoning, we are going to end up like Toronto and instead of allowing RCG to gradually build infill supply, we will need to allow 6 story wood frame multi family as of right everywhere and communities will be crazy impacted or prices will be crazy expensive
This week council decided 6 storeys was too much for this site:
But now an interesting question is will those 3 lots revert to RC-2? I'm not sure what happens to the LOC application after it's rejected by council? Would it still be 'alive' in some sense so it could be captured by the grandfathering process for previous/active applications?
I think the intent of the grandfathering process is simply to avoid any liability on the City that they could incur by harming ongoing developments, or those previously approved. The grandfathering won't apply to zones other than the Low Density Residential bunch.
Admin will likely interpret the motion to "repeal blanket rezoning," as written by Cllr. Chabot and passed by Council, as instruction to do the following:
- Check if an R-CG parcel used to be R-C2/1/etc. before Aug 6, 2024
- Check if a Development Permit has been received for that parcel, and hasn't been rejected since Aug 6, 2024
- If yes on the DP, keep it R-CG, if no, revert it to the zone it was before
With some other funky stuff about LAPs or H-GO or R-G or I don't know, and Admin probably doesn't either given the gap between what Council has verbally said vs. what they have approved on paper. There will hopefully be some clarification of that through the next couple months as Council prepares for the Public Hearing.
But basically, now that this LOC has been denied, those parcels remain R-CG - and since they were R-C2 before, they'll go back to R-C2. The failed LOC for 6 storey won't factor into it.
I agree your last sentence is the likely outcome on this particular situation, but there is a crazy amount of ambiguity here. Does a DP for a relaxation on a fence or deck count? Or a temporary use, or a new garage or addition to a home that does not include a new unit?
Or more importantly, what happens if you get a DP in the hopper tomorrow for say a garage suite...but the process drags and it is ultimately rejected or just fizzles a couple years from now? Presumably you keep your zoning. Pretty sure the backyard/secondary suite DP fee is currently $0...Point a/b below doesn't specify at all, and taken literally means a fence relaxation should retain your zoning.
Reverting blanket rezoning is not the real issue at hand. Council is also trying to slash RCG typology from 4+4 to 3+0 based on density calculation (75 UPH v 60 UPH) and interpretation of Unit (vs suites)
This will effectively eliminate new family-sized rental housing in Calgary's established communities.
The moment you need to increase your living situation from 2-bed to 3-bed, you're forced to the suburbs.... unless you have $1m for a new infill.
